boler axle specs TRAILING AXLE - Fiberglass RV
Old 11-11-2024, 09:20 PM   #1
Trailer: boler
Manitoba
Replacing a 1975 boler 13 original rub r ride trailing axle, can anyone help with what the original start Angle was. Mine appears to be 22 deg up with no body on the frame. Is that correct. Thanks in advance!
greghound is offline   Reply With Quote
axle, boler
Did boler ever use trailing axle greghound Towing, Hitching, Axles and Running Gear 1 11-08-2024 06:53 PM
Specs in manual? Or specs on tow bar? EllPea in CA Towing, Hitching, Axles and Running Gear 18 11-10-2020 05:43 PM
Replacing an Axle - leading arm to trailing arm Roy in TO Modifications, Alterations and Updates 38 11-21-2010 02:00 AM
New Axle -- Leading or Trailing Arm? CliveAlive Towing, Hitching, Axles and Running Gear 3 01-26-2008 01:12 AM
New Axle -- Leading or Trailing Arm? CliveAlive General Chat 0 01-01-1970 12:00 AM
