Can I tow an Oliver LE2 with a 2006 Toyota Tundra Double Cab? - Fiberglass RV
Old 06-11-2025, 12:24 PM   #1
Can I tow an Oliver LE2 with a 2006 Toyota Tundra SR5 Double Cab?
I have a first generation, 4x4,Tundra SR5 with a 4.7L V8 engine, and the Tow Package that includes the oil cooler and upgraded alternator. I ascend (and descend) the Pacific Northwest mountains. The truck has a an aftermarket electric brake controller and an Andersen WDH.
Tundra Specs from Owner’s Manual:
GVWR = 6600 lbs. (2994 kg)
GVAW Front =3500 lbs. (1588 kg)
GVAW RR = 3760 lbs. (1706 kg)
Max Gross Trailer Weight = 6700 lbs. ((3039 kg)
Hitch Carrying Weight = 670 lbs (304 kg)
Max Cargo Weight = 600 lbs. (272 kg)
Oliver Specs:
GVWR = 7,000 lbs
Dry Weight = 4.900 lbs
Tongue Weight = 490 lbs.
Looks like the DRY weight of the Oliver (4900 lbs) is little below the "80% Towing Rule" with 460 lbs to spare. (Tundra Max Trailer Weight= 6,700 lbs x .8 = 5,360 lbs.) and (5,360 lbs - 4,900 lbs = 460 lbs)
However, the GVWR weight of the Oliver (7,000 lbs) is 300lbs more than the Tundra's Max Gross Trailer Weight (6700 lbs).
Assuming that I add air bags and beefier brakes to the Tundra, can I safely tow an LE2?
Thanks in Advance,
Jay Moeller is offline   Reply With Quote
Old 06-11-2025, 12:43 PM   #2
Dry weight doesn't include options. Seems marginal. Towing upgrades help prevent a melt-down, but you will be working the smaller engine hard on grades. Personally I would want the 5.7L for towing a larger trailer like the OE2. I live in the mountains, and Toyota didn't even stock the smaller engine (past tense, since Toyota has now abandoned the V8s altogether).
Old 06-11-2025, 02:04 PM   #3
ShelbyM's Avatar
Trailer: Casita SD
Check your door sticker for your actual payload. Check the Oliver Owners forum for actual tongue weights. If that doesn't discourage you, it seems most Oliver owners end up with 3/4 or one ton trucks, regardless of how they started out.
Eschew vanity links!
Old 06-18-2025, 10:09 AM   #4
Trailer: Escape
I would say NO, if you want a comfortable, safe towing experience. As you mentioned you are right at the 80% rule and that is with empty tanks and an empty trailer.
stratos119 is offline   Reply With Quote
Old 06-18-2025, 02:48 PM   #5
Trailer: 1980 Trillium 4500
Oliver Specs:
GVWR = 7,000 lbs
Thanks in Advance,
All of those numbers look great on paper but you will find none of them are the actual weight of any of them. The manufactures weights can not be trusted unless there is an actual legal weight ticket issued.
The best thing to do is load up the trailer, water, propane, food, coolers, camping chairs, bicycles, clothes, dog, and tow vehicle and hitch them up just as you plan to go traveling. Now go to a truck scale that has a segmented scale, CAT SCALES are one of the ones that has that type and they are at most large truck stop travel centers. When you park on the scale position each axle on a different segment. If you have a 2 axle trailer both of those axles can be on the same segment. Now have them weigh you and go and get your weight ticket. Those are the number you will need when adding or removing items for either vehicle.
A first weigh at a CAT Scale costs $14.75, and reweighs within a 24-hour period at the same location cost $5.00, according to CAT Scale.
All of this is with my assuming the you have a WDH and it is set up properly because if not your axle weight can be off.
An additional note is to make sure that your tires are inflated to the proper cold pressure based on the actual weight on that axle and what the tire manufacture says to have them inflated to.
1980 Trillium 4500 with front 1/2 bath, toilet, lavatory, 305watts solar, TriStar 45 MPPT controller, 2002 Chevy S-10 Crew Cab, 4.3, 4WD, Leer Shell
1977 Trillium 1300, front bunk beds. sold
2004 Damon Challenger 335F, fiberglass Class A, finally retired in the Monster.
ROBERT ONEILL is offline   Reply With Quote
Old 07-14-2025, 08:54 PM   #6
Steve Outlaw's Avatar
Trailer: Oliver
Oliver Specs:
GVWR = 7,000 lbs
Thanks in Advance,
This vehicle is far from optimal for an OEII. Many of us (owners) have long since moved up to heavy duty diesel trucks. A 3/4 ton is usually sufficient although I tow with a 1 ton Silverado for the extra payload it provides. We regularly have over 3000 pounds of cargo and people and dogs in the truck. Our entire rig, ready to camp with a full tank of fresh water, weighs in at just under 18,000 pounds.
Your posted tongue weight of 490 pounds is far from accurate. The tongue weight for an average OEII will be in the neighborhood of 600-650 pounds. That is pushing the limits of your light duty 1/2 ton truck. A fully loaded OEII with all your gear should tip the scales at about 6000 pounds, maybe more or maybe slightly less. Ours always weights around 7200 pounds but it was originally equipped with larger than standard (3500 pound) 5200 pound axles and heavy duty 12 inch disc brakes with 12 ply commercial light truck tires.
Your truck's cargo weight of 600 pounds is dismal. By the time you take into consideration the weight of two passengers and the tongue weight of the trailer, you're already overloaded.
Now you see why many of us tow with large diesel trucks. And, incidentally, most of us get 13-14 mpg. Nobody was ever sorry they had a tool that surpassed the needs of the job.
Steve and Tali - Dogs: Rocky and our beloved Storm, Reacher, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 07-15-2025, 07:01 AM   #7
Originally Posted by Steve Outlaw View Post
…Your truck's cargo weight of 600 pounds is dismal. By the time you take into consideration the weight of two passengers and the tongue weight of the trailer, you're already overloaded...
I noted the listed specs from the owner’s manual included a separate 670# hitch weight rating. Since that’s greater than the rated 600# cargo capacity, I concluded that it must not include tongue weight. A total payload of 1270# makes more sense than 600# for a half-ton truck. The OP should be able to verify that on the door jamb.
Since the OP will be using a WDH, a trip to the scales with the fully loaded combined rig to check final axle and gross vehicle weights is necessary to determine if the rig is within specs.
Even so, I agree with your bottom line- very marginal. “Within specs” and “comfortable towing” with some margin for severe conditions are two different things.
Old 07-16-2025, 02:36 AM   #8
John in Santa Cruz's Avatar
Trailer: Escape 21, behind an '19 Ferd Expedition
Mid Left Coast
A modern full size 1/2 ton truck should have a payload of around 1500-1700 lbs. My old 2008 Tacoma 4*4 access cab was about 1200 lbs. You really need to weigh the actual truck with a full tank of fuel and subtract that from the GVWR.
Old 07-16-2025, 02:38 AM   #9
Mid Left Coast
Oh, double cabs often take quite a lot away from the payload as they start with a higher curb weight.
oliver
FL | SOLD: 2003 19’ Scamp Deluxe 5th Wheel with 2006 Toyota Tundra SR5 Access Cab 4.7L V8 densmitt Classified Archives 10 02-09-2019 05:45 PM
Scamp 19 Deluxe and 2017 Tacoma double cab I4 MrBig1 Towing, Hitching, Axles and Running Gear 18 08-30-2017 11:13 AM
2006 Toyota Tundra & 1997 Scamp 5th wheel Nita F. Problem Solving | Owners Helping Owners 3 10-01-2007 02:42 PM
Tundra Bed Cover and Tool Box for Tundra Double Cab Terrance Classified Archives 0 02-02-2006 04:33 PM
Towing with Toyota Tundra Legacy Posts Towing, Hitching, Axles and Running Gear 10 05-27-2003 11:30 AM
