Converting 4pin to 7pin - Fiberglass RV
Old 05-02-2017, 06:04 AM   #1
ChrisDunbar's Avatar
Trailer: Trillium 1300
Nova Scotia
My truck is currently wired for 4 pin along with the trailer. The trailer, however, does have brakes and the wires have been nipped to convert to 4 pin. For whatever reason. Anyway...I would like to switch everything back to 7. I'm just a little confuse about what I need for the truck. Is something like this the ticket? https://www.amazon.ca/gp/product/B00...f_rd_i=desktop
The current 4 pin on my Ford Escape is wired through the brake lights and up to the battery. Am I right that the unit in the link plugs into the existing 4 way and then has the extra wiring for the controller, alternator, etc.?
ChrisDunbar is offline   Reply With Quote
Old 05-02-2017, 06:45 AM   #2
mszabo's Avatar
Trailer: U-Haul VT16
Yep
Old 05-02-2017, 07:13 AM   #3
As I understand what you wrote the trailer pig tail has also been cut back to 4 pins
When you get to that part there are TWO standards for wiring on the trailer 7 FLAT pin pigtail.
There's the "RV standard" color coding and the "Traditional standard".
The pin positions around the 7 pin plug are the same but the colors are different.
Easiest way to figure out what you have is determining what color wire lights the tail and running lights!
If it's GREEN you have the RV standard, BROWN if it's traditional standard.
Don't ask me why we have standards that are then not followed.
Joe
Old 05-02-2017, 07:50 AM   #4
Nova Scotia
Joe
Yep. It's been cut back. Thanks for the heads up.
Old 05-02-2017, 10:38 AM   #5
7 pin
As you know, the 4 pin provides for tail/stop/turn lights and a ground wire.
When your trailer has brakes, and a battery, you need one 12 volt "hot" wire. from your truck battery direct to the 7 pin connector.
And another 12 V wire to supply power to the brake controller, and from it to the 7 pin.
If you're not sure, It may be best to take it to a trailer shop and let them install everything.
Old 05-02-2017, 03:06 PM   #6
Barb and Alan's Avatar
Name: Alan & Barb
Trailer: Bigfoot 25RQ
Maybe not?
The Amazon link appears to be for a plug that has 7 pins but only supports 4 wires going in. You'll not have brakes if that's the case or a 12V feed from your TV.
Barb and Alan is offline   Reply With Quote
Old 05-02-2017, 03:29 PM   #7
WRONG! That's what the BLACK, WHITE, BLUE and YELLOW WIRES ARE FOR
His question is
Joe
Old 05-02-2017, 03:39 PM   #8
The best advice is to take your tow vehicle and trailer to trailer shop and have them wire thing properly. Attempting to so otherwise without knowledge is risky at best. Trailer fires aren't fun.
Old 05-02-2017, 03:48 PM   #9
On another thread or forum maybe two owners did just that and neither "Expert" including a Toyota dealer hooked up the back up lights
Old 05-02-2017, 04:20 PM   #10
John in Michigan's Avatar
Trailer: 1979 Boler 1700
ChrisDunbar, 18 months ago I was faced with the same situation as you:
- I had to add a brake controller in my 2011 Ford Escape which was NOT pre-wired. This requires:
1. Running a wire (red) from the brake light switch wire under the dash to the brake controller.
2. Running + and - power wires (black and white) from the tow vehicle battery through the firewall to the brake controller.
3. Running a brake power wire (blue) from the brake controller to the 7 blade connector in the tow vehicle.
4. Mounting the brake controller (I put a mounting block in the console tray. There is not enough space under the dash.)
- On my Trillium 4500, I had to wire the 7 blade connector. PO had a 6 pin connector. Also I replaced and connected new brakes.
I agree with Byron K that the brake wiring particularly the wiring in the tow vehicle is best left to a knowledgeable mechanic, unless you have vehicle wiring skills.
John
EDIT: The Trillium, Boler and most other FGRVs don't have back up lights, so wiring in the backup light wire at the 7 blade connector on the tow vehicle is unnecessary.
Old 05-03-2017, 12:27 AM   #11
Trailer: In the Market
This Converts your 4 pin to 7 to battery an breakers also wiring for brake Controller. Its what I installed on My Mercury Mariner!
https://www.etrailer.com/Accessories...ler/ETBC7.html
You will also need a brake Controller (Proportional Controller cost a little more or Time Delayed) Look at 125 - 360 degree self leveling.
https://www.etrailer.com/s.aspx?qry=...-sb-Price-pa-1
If your handy with Tools you can buy it all and install for less than $150
Randy B. is offline   Reply With Quote
Old 05-03-2017, 05:43 AM   #12
Flimsy excuse, do the job right or not at all
So happens my Casita does have backup lights.
And it appears here that Scamp does too.
http://www.scamptrailers.com/ask-sca.../exterior.html
The factory harness I installed in my 06 Liberty and the factory installed 7 pin in my Silverado both have the backup lights active.
Joe
Old 05-03-2017, 08:00 AM   #13
"Right" only needs to mean safe. It doesn't have to mean complete. I see no reason you have to run extra wires in the tow vehicle to support a function that doesn't exist on the trailer or isn't needed. If you don't have or need back-up lights, why wire them? If you don't have a battery or need on-road charging capability, why wire a charge line?
Of course, if you think you might want those functions in the future, best to do it all at once.
Old 05-03-2017, 08:08 AM   #14
Nova Scotia
Ugh. I knew I'd regret asking an electrical question. Thanks for the helpful responses.
Old 05-03-2017, 09:37 AM   #15
Electrical questions, tire questions, solar questions... Fun!
Old 05-03-2017, 09:41 AM   #16
Joe
Joe Romas, I have to agree with you that it makes sense to go ahead and attach the tow vehicle backup wire to the center pin on the 7 blade connector.
Old 05-03-2017, 10:27 AM   #17
I don't know what year your tow vehicle is but on newer vehicles the factory IBC is tied into the vehicle's computer. The brake controller is programmed to work with the vehicles ABS , anti sway, traction control , vehicle brakes etc . My factory brake controller can be set and can be visually monitored on my EVIC.
IE; If my trailer brakes accidently become disconnected while towing , I get a warning light on my EVIC screen
This requires that not only must the brake controller have the 4 wires to run the brakes but a cable must be run to link the brake controller to the computer and the computer must be programmed to accept the signal.
Installing a brake controller is a DIY project (maybe) but installing the computer link and programming means going to the dealer.
Many dealers charge $300 to $500 for this service.
I am not telling you that you can't DIY or you have to integrate the brake controller to the vehicle just the problems I ran into.
When I bought my 2014 truck I purchased the factory IBC at a cost of $230 . I could not install an after market brake controller for anywhere near that price and I didn't try.
Again , I am not familiar with your vehicle , so disregard my comments if they don't apply to you.
Converting Scamp 5er Loft peterh Modifications, Alterations and Updates 65 07-12-2019 06:58 PM
What is this 20amp 4pin for? Caseyb476 Modifications, Alterations and Updates 17 04-18-2014 05:06 AM
4 pin TV 7pin Scamp '89 16' Steve and Rosemary Towing, Hitching, Axles and Running Gear 8 03-10-2010 08:46 PM
Converting Trillium 4500 3 sleeper to 4 sleeper? Booker B. Problem Solving | Owners Helping Owners 2 03-01-2008 10:39 PM
Converting Freedom to Spirit seating Legacy Posts Modifications, Alterations and Updates 8 06-01-2003 08:55 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
