Dexter axle bracket - Fiberglass RV
Old 11-05-2024, 09:41 PM   #1
Trailer: boler
Manitoba
Dexter axle bracket
I'm getting ready to order a dexter axle for 1975 boler 13. The original axle bracket has the top of the axle tube approx 1 1/4 " from the top of the axle bracket. The standard dexter bracket has the axle tube right at top of the bracket. Do I have to take this in account. All suggestions say order standard bracket trying to add picture
greghound is offline   Reply With Quote
Old 11-06-2024, 06:44 AM   #2
Are you otherwise ordering the exact same specs as OEM? I’m thinking that’s leading, 22.5 degrees down, 4-lug? What weight rating?
Personally, I’d want a bit more underbody clearance than stock. I’m honestly not sure what’s feasible with a leading configuration, if that’s indeed what you have.
Old 11-11-2024, 07:41 PM   #3
Trailer: boler
Manitoba
Well from what I read I just assumed it was leading but now I see I have a trailing axle. It's definitely the original axle. It sat nice with just the top part of the tire exposed. I have the frame off now and without the body the original axle seems to be 22 deg up. Is it possible the original axle was 22 deg up new and isn't just sagging??? I don't want to order 22 deg up and find out it sits way too high . Any thoughts appreciated!!
Old 11-11-2024, 10:11 PM   #4
Up angle sits lower. Down angle sits higher. Up and down are referenced from the axle tube to the wheel hub. In leading configuration, the wheels lead. In trailing configuration, the wheels trail. Trailing is the way torsion axles are intended to be installed.
Older units with the Boler/Scamp frame design were mounted in the unconventional leading configuration to avoid the center drop floor and mount the axle directly to the main frame rails under the dinette floor. The axle arms point forward and downward, typically 22.5 degrees down on 13’ers.
Brakes were uncommon on 13’ers in the early years. Under heavy braking with a leading axle, the wheels can lock up and cause “crow hopping” rather than skidding smoothly. As brakes became more common, manufacturers found ways to accommodate the standard trailing orientation. Trailing axles are mounted forward and low under the drop floor using blocks under the frame rails. The axle arms point rearward and upward into the wheel wells, commonly 22.5 degrees up on 13’ers.
This is my 13” Scamp with a 22.5 degree up axle in trailing configuration. The trailer was unloaded in this photo, and the wheel arch is approximately even with the top of the white wheel. The wheel arch on the curb side is cut lower due to the door and part of the wheel is covered. Scamp now uses a zero degree axle on 13’ers, which sits about 1-1/2 to 2 inches higher. That gives a bit more tongue and bumper clearance, and it’s easier to wrestle the wheels in and out of the wheel wells when changing tires. 22.5 down gives about 3-4 inches of added height.
How about a photo of your frame and axle? It would also be helpful to see a photo of the trailer from the side before the frame was separated if you have one.
Old 11-12-2024, 06:09 PM   #5
Trailer: boler
Manitoba
Thanks for your help! I will definitely post some pictures for you to look at. I just have to figure out how lol. I'll look onto Flickr or something similar. When I try as an attachment my samsung phone only lists came, not gallery as an option.
Old 11-13-2024, 06:28 AM   #6
Photos are tricky.
Open a new post and look for the paper clip icon in the tool bar (not the globe-and-link). If you don’t see it, click “go advanced.” When you click the paper clip, a new attachment window opens. Choose up to four photos, then hit the “upload” button. Wait until the files drop down into the attachments list. It may take a while if the files are large. Return to your post, add text, and submit. The photos will appear in a clump after the text.
If you want to insert the photos within the text (as I did in my earlier post), there’s an extra step. After uploading the photos, return to the post. Place your cursor where you want a photo to appear. Click the little down arrow next to the paper clip and a drop-down list of attachments will appear. Click the photo you want, and you’ll see an attachment reference appear in the text. Repeat with all photos, placing them wherever you want within the post.
On my smaller iPhone it helps to zoom in to tap the tiny arrow and the right photo. Before submitting your post, use the “preview” button to see what your post will look like with the actual photos.
It’s a bit cumbersome at first compared to more modern social media platforms, but it will quickly become routine.
Old 11-13-2024, 01:34 PM   #7
FL
Search my posts . I had to make my own bracket to make it work. Also bought me a couple " frame lift. There's lots of pictures. Good practice using the forum search tool.
mosquito13 is offline   Reply With Quote
axle
Dexter 9 vs Dexter 10 glamourpets Towing, Hitching, Axles and Running Gear 10 11-28-2024 11:12 PM
Bolt on Dexter #9 axle install with side mount hanger rudock1 Towing, Hitching, Axles and Running Gear 1 03-26-2008 01:13 PM
This is the Dexter axle price I was quoted Kevin K General Chat 12 01-19-2008 11:58 PM
Dexter axle question Kevin K Towing, Hitching, Axles and Running Gear 17 12-22-2007 11:30 PM
Dexter axle Don G Care and Feeding of Molded Fiberglass Trailers 19 12-13-2005 09:17 AM
