09-30-2021, 12:10 PM
Trailer: Currently shopping
Highlander for Casita??
We have a 2016 Toyota Highlander with the V6. We have been towing an U-haul 13 with absolutely no issues but are now looking at a Casita 16 with bathroom. I think about 1800 pounds dry and likely about 2300 ready to camp. We have heard of others doing this but it seems the majority are from parts of the country with less mountains than we deal with here in the northwest. We had a prior tow vehicle with a 3500 pound rating but it was very inadequate for the U-haul. The Highlander is supposedly rated for 5000, so the rating is technically adequate for the new trailer. Our concern is that our previous vehicle was also technically adequate but was very slow climbing hills and plain scary in passing and high trans temps were common. Can some of you with a similar setup who have dealt with our situation relate your experiences?
Thank you
BTW, we are looking at the Casita Saturday.
09-30-2021, 12:55 PM
Administrator
Trailer: 2015 Escape 21 (was 1999 Casita 17 Liberty)
 Hi, Don. It'll probably be okay for a 16, but tongue weight is also an important consideration.
09-30-2021, 01:27 PM
NC
We tow our 2021 17' Casita with our 2018 Highlander AWD and it does awesome. We only get about 15 mpg or so but we haven't had any issues or concerns with speed or making it up a hill.
Steve Lineberry - Based out of Charlotte, NC and part of Team Cragmama
2021 Casita Heritage Deluxe 17'
2018 Toyota Highlander AWD XLE Anderson WDH
My Casita YouTube videos
09-30-2021, 04:49 PM
The hitch is rated for 350 pounds so should be adequate but I will check more to be sure, so thank you for mentioning that. For the reply from the couple with the 17 footer that helps also. Your Highlander appears to be rated comparably to ours and you are doing well with your heavier trailer so we should have even more margin.
Once again, thanks to both of you.
09-30-2021, 07:38 PM
NC
No problem, glad to help. For what it’s worth, my Highlander’s hitch max tongue weight is 500 lbs.
10-01-2021, 06:31 AM
We towed our Uhaul CT13 with a Honda CRV. Right at the vehicles limit, but it worked OK. Uhaul has since been sold, replaced by a Casita 17 and towed with a full size truck. The Casita 16 has a lighter tongue weight than the 17 because the axle is farther forward. Find the thread here, Trailer Weights in The Real World, for a chart on tongue and total trailer weights. I recall seeing some Casita 17's with tongue weights near 500 lb, don't remember weights on the 16's.
10-01-2021, 10:03 AM
Trailer: '16 Parkliner
Iowa
Mountiains? No Prob's. Just get handy with downshifting on the up grades AND down grades. Use the truck lanes. Don't try to keep up with the speeders. Take your time and arrive alive.
10-01-2021, 12:01 PM
Name: Howard and Kim
Trailer: Escape 17B:former Scamp 13
We had a Subaru Forester with our 13'Scamp and found it sluggish in the mountains. Now, we tow our 17' Escape with a 2016 Highlander rated at 5000 lbs. It's great! You need to be prepared to downshift for downhill. We find we can pass others going uphill.
10-06-2021, 10:44 AM
Trailer: Trillium 5500
Towing with a Highlander
Hi -- we tow our Trillium 5500 with a Highlander (and we're in the PNW). The 5500 weighs approx 2400# w/out her tanks filled and the Highlander does great. One thing we have found is that a weight distribution system makes a big difference in not "dragging" the Highlander lower. Plus, it's soooo much more stable than it was without. We have this one:
Fastway e2 Weight Distribution w/ 2-Point Sway Control - Trunnion
10-06-2021, 04:17 PM
Highlander
Thank you
We bought our 2013 Highlander specifically to tow out 2013 Casita Spirit 17’ Deluxe, and have since logged over 80,000 miles over the US and Canada. We have the towing package that includes tranny cooler, oil cooler, and heavy duty alternator, and a WDH. We have been very pleased and will eventually replace our Highlander with a new AWD version. That being said, in our travels, there have been times where we could have used more power. We have never gotten over 4,000 rpms and we’re never in danger of red lining. In those climbing situations, we have kept up with the Class A diesels and the F-350 duallies pulling 11,000 pound 5th wheels. The rest of the time (99.9%) we hum along at 1800 to 2200 rpms and enjoy the 26 mpgs we get unhitched sightseeing. We are very cognizant of GVWR and tongue weight so we have never ever felt unsafe in 8 years of towing.
10-06-2021, 07:12 PM
I have over 10K mi. towing my C17 with my 2017 Highlander with a WDH and factory towing transmission cooler. It has plenty of power to run with traffic and gets 14 MPG running interstate speeds. I recently started using a Scanguage to monitor transmission temps. the fluid stays under 200deg. F. flatland towing with outside temps. in the 90's. In the mountains I had a 5 mile long uphill grade going over a mountain and the transmission temp reached 209F near the top of the grade but cooled down fairly quickly. Some people on the Highlander forum have added an additional trans. cooler directly behind one of the bumper air slots. Some have suggested making a duct for the existing cooler to provide better air flow to the factory cooler. I have not had time to address the issue but may try one or the other recommendations. We are well satisfied with the Highlander. We just made a 840 mi. run taking 15 hours in one day with no issues.
Eddie
10-06-2021, 08:30 PM
Trailer: Casita SD
trans temp
You might want to do some research but I don't think 209 is anything to worry about with modern fluids. I prefer more capable tow vehicles but if temps like that only showed up in extreme situations I wouldn't be concerned.
10-17-2021, 06:47 PM
Everywhere
I towed an Escape 19 all over with a 2015 Highlander. The only problem I had was being a bit short on power for high-altitude climbs, like above 8,000' or so. Even then, it was just a matter of staying in the right lane at 40-50mph for a few miles. No overheating, and "sport" mode gave enough engine braking on the way down. At lower altitude, like the Cascades or the Grapevine, it had no problems at all climbing at the speed limit. At 2300lbs instead of ~4500, you'd probably be fine even at altitude.
03-10-2022, 10:39 AM
Tow Hitch
Is your hitch a factory installed option or third party? Thanks.
03-10-2022, 11:04 AM
We have the factory tow package but I installed the actual hitch myself. However, given the skyrocketing price jumps for FG trailers we will stick with the CT13 for now. Thank you to all who have replied.
03-10-2022, 11:32 AM
Trailer: 1989 Lil Bigfoot
CA
Originally Posted by Eddie Longest
… I recently started using a Scanguage to monitor transmission temps. the fluid stays under 200deg. F. flatland towing with outside temps. in the 90's. In the mountains I had a 5 mile long uphill grade going over a mountain and the transmission temp reached 209F near the top of the grade but cooled down fairly quickly. Some people on the Highlander forum have added an additional trans. cooler directly behind one of the bumper air slots. Some have suggested making a duct for the existing….
Eddie
I am interested in more details about the Scangauge? Bluetooth? Does it work with and without a cooler?
Best,
EllPea in CA
03-10-2022, 03:00 PM
SW Florida
Scangsuge is the engine/powertrain monitoring tool. https://www.scangauge.com/
Sergey
03-10-2022, 03:18 PM
NC
I bought the hitch from the factory. I told them i was going to install it myself. I took it to the installer that was going to install my 7-pin and he did, hitch, 7-pin and brake controller all at the same time.
The factory would not install a 7-pin on my highlander.
03-10-2022, 04:52 PM
Trailer: 2006 Scamp 19 Deluxe
Enchanted Mountains of Western New York State on the Amish Trail in Cattaraugus County!
Scangauge, which plugs into OBED vehicle plug so info comes from your engine's computer!! Bluetooth ties up your cell phone.
03-12-2022, 05:59 PM
Trailer: U-Haul 1985
Thank you
I think that you will find your Casita weighs well more than 1600lbs. You can review many trailer weights in the real world in the thread that is linked at the bottom of my comment. If you have a well optioned 17ft Casita with a bathroom you are 2800-3200lbs. (Dont count on paperwork, most will show a lighter weight than actual). Good luck on your search, the more homework you do, the less chance of buyer's remorse.
https://www.fiberglassrv.com/forums/...rld-43010.html
