If adding brakes, does wheel size matter? - Fiberglass RV
Old 04-15-2015, 07:07 PM   #1
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Suppose a trailer has 13" wheels, with 5 on 4.5" lug pattern, and also has backer plates for attaching a brake kit. If a change were made to 14" wheels of the same pattern, would this affect the sizing of the brake kit? (Assume there's no problem with wheel well space or anything else... this is sort of hypothetical.)
Thanks in advance for your wisdom!
Old 04-15-2015, 07:22 PM   #2
Mike, it's about the size of the hubs. The brake pads must make contact to the hub. Which CAN be a different size than the wheel. Those are two different things. However, I've always seen where the hubs are matched to the wheel.
Those running 25-30" tires/wheels on motor vehicles are probably running the original hubs.. which means the brakes still work....
Old 04-15-2015, 07:46 PM   #3
floyd's Avatar
Both 10" brakes and 7" brakes with a 5 on 4.5 bolt pattern will accept all common sized trailer wheels of the same pattern.
The 7" brake hub was developed to accommodate 8" wheels such as those found on snowmobile trailers, that is why the lighter axles on many 13ft fiberglass trailers have 7" brakes even though they are commonly supplied with the same 13" wheels as their larger siblings which have 10" brakes.
13,14, and 15" trailer wheels all have adequate clearance to fit over 10" brakes which are commonly supplied on 3500# axles.
Old 04-15-2015, 10:14 PM   #4
Mike Magee's Avatar
Great info, thanks!
Old 04-15-2015, 10:17 PM   #5
David Tilston's Avatar
Also thanks, good info.
brakes
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
a matter of roof support Cat futrell Problem Solving | Owners Helping Owners 5 02-11-2013 09:01 PM
Exercise your gray matter Roger C H Jokes, Stories & Tall Tales 5 10-20-2012 06:48 AM
Size does matter Mike Magee General Chat 10 06-09-2012 06:24 PM
Size does matter (with tires) Bob H Towing, Hitching, Axles and Running Gear 21 07-16-2010 12:01 AM
