Jeep towing - Fiberglass RV
Old 08-07-2017, 08:39 AM   #1
Trailer: In the market
Kentucky
Jeep towing
Is there a 2 person trailer with bath/shower out there that a Jeep Renegade FW 2.4L 4cyl can safely tow? The manual says 2000lbs towing capacity. Thanks!
llonwheels is offline   Reply With Quote
Old 08-07-2017, 09:01 AM   #2
The Minimalist's Avatar
Louisiana
You can go to Trailer Weights in the Real World, located here:
http://lakeshoreimages.com/spreadsheets/Weight.xls
Filter the total column for 'less than or equal to 2000' and you will get a list of possibilities. Those in the 'Event' column were actually weighed at various rallies, loaded ready to camp. The 'Shared' ones are weights sent in to the creator of the list.
My main concern with Jeep towing would be the towing stability of a short wheelbase vehicle built for off road ground clearance. If it is jacked up and has big off road tires, I would be even more concerned.
What is the max tongue weight on the Renegade? You will have to be more careful with trailer loading with a short wheelbase vehicle.
As to towing capacity, you might want to consider something somewhat lighter than the max to allow a margin of safety.
You will likely have to forego the shower/bath and use campground facilities.
Clif
Old 08-07-2017, 11:21 AM   #3
Trailer: 2012 Escape 19
Yes, the Scamp 13' can be under 2000 lbs if you don't heap it full of stuff, and it will tow quite nicely (although with a 4 cyl engine you will not be a speed demon).
https://www.scamptrailers.com/showro...pped_rev_2_633
Also, there is the Happier Camper, but they are in CA and are too new for very many used ones to be available. Not sure if they can be configured with a shower, but a porta potty is easily added.
https://happiercamper.com/media-gallery/
Then there's the Weiscraft Little Joe (no bathroom) and Ponderosa (wet bath). Not plentiful, but available by order from CO.
Little Joe Lightweight Trailer - Compact Camper Trailer for 2 by Weiscraft Trailers
In the used market, you might also come across a 13' Boler or 13' Casita. They are all in the same weight range, more or less. Not many of these have baths, but maybe.....
Jeep Wrangler, Short Wheelbase, for Towing John Hussey Towing, Hitching, Axles and Running Gear 26 01-02-2018 05:35 PM
Towing Scamp with Jeep Wrangler Mark Saiger Towing, Hitching, Axles and Running Gear 20 03-12-2012 10:25 PM
Towing w/ a Jeep? matt scott Towing, Hitching, Axles and Running Gear 26 09-06-2011 08:53 PM
Towing Mirrors - Jeep Wrangler Ryaine Towing, Hitching, Axles and Running Gear 9 05-28-2011 10:58 AM
Towing with a Jeep CJ, YJ, TJ, LC FJ-40, LR SIII 80? jack smith General Chat 62 03-08-2007 10:25 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
