Just got a new to me
Scamp and am having an issue with the turn signal/brake/tail
lights on the camper. I have a few questions.
There is a four pin flat connector coming out of a 2009 Toyota Sienna. That runs into a four pin flat to seven blade adapter, which runs into a seven blade connector on a 2005
Scamp.
The issue is - whenever I uses either turn signal, all of the exterior
lights blink. When I step on the
brakes, all of the exterior
lights come on.
Currently the ground wire on the adapter is not connected to anything. I have tried connecting it to the frame of the
Scamp and to the frame of the Sienna, but I am still seeing all the lights coming on. I am not sure that I need this ground wire - do I need this ground wire? Also I am not sure here it should connect to - if I do need it, where would I connect it?
Anybody have any thoughts about what might be causing all of the exterior lights to turn on?
The adapter I'm using -
https://hopkinstowingsolutions.com/?.../7-blade/47205
Thanks!
