Lil Bigfoot Axle and adding brakes - Fiberglass RV
Old 05-13-2023, 04:36 AM   #1
paulaj's Avatar
Trailer: 79 Boler
Smile Lil Bigfoot Axle and adding brakes
Hi all, I can't seem to find my answer by searching so I could use some help.
I have a 1992 Lil Bigfoot (13' about 1400 lbs) with no brakes. There are backing plates present to attach brakes. I want to add brakes as my new Subaru requires brakes to tow upto 2500 lbs.
The trailer shop wants to know what size axle it has and is there a lable on the axle I can read. It's 40 years old and has about 20 layers of rust proof coating so...there is no lable.
This may be an easy answer for some of you.
What size axle would it have and what size brakes?
Thanks
paulaj is offline   Reply With Quote
Old 05-14-2023, 05:37 PM   #2
David Tilston's Avatar
The backing plates will determine the brakes that you can put on the axle. This is why they’re asking. Pull one of the wheels off and measure the center to center spacing of the bolt holes. That will tell your trailer shop what they want to know.
Old 05-14-2023, 10:36 PM   #3
Trailer: Lil bigfoot
There’s quite a few threads about the challenges of these axles. But I haven’t read about anyone adding brakes to the original axles.
My 87 lil bigfoot also had backing plates but no brakes. Given the age of the trailer and life expectancy of the axle it’s probably a good idea to think about a new axle with brakes. I just replaced my axle over the past few months. I didn’t really realize how worn out it was until I pulled the trailer on the new axle. Much smoother, the trailer doesn’t bounce around nearly as much on rough roads. The old one was very stiff and had sagged to the point of the tires rubbing the wheel wells. Probably not the news you want but worth considering if the axle is original.
Nick G is offline   Reply With Quote
axle, bigfoot, brakes
Adding brakes to Scamp 13- cost? And other service issues. CarrieR Problem Solving | Owners Helping Owners 17 03-30-2016 07:47 PM
Replacing axle, adding brakes, changing wheels? Zennifer Towing, Hitching, Axles and Running Gear 12 03-06-2016 11:35 PM
Towing Lil Bigfoot w/o brakes in CA EllPea in CA Towing, Hitching, Axles and Running Gear 1 07-23-2015 07:50 PM
1980 17.5 Bigfoot Axle and Brakes COLIN R Towing, Hitching, Axles and Running Gear 5 02-14-2011 09:08 PM
Adding brakes to Scamp Quint Care and Feeding of Molded Fiberglass Trailers 27 01-26-2006 08:07 AM
