Mileage comparisons - Fiberglass RV
Old 04-30-2024, 12:48 PM   #1
Trailer: Shopping
New Brunswick
Mileage comparisons
Hi all,
Is there a huge difference in mpg between pulling a 13’ Scamp vs a 13’ Trillium? We are currently looking at both, both have their pros and cons. I know there are many factors involved in figuring out the mpg but just looking for general ideas or opinions. Thanks so much!
Atmelanson is offline   Reply With Quote
Old 04-30-2024, 01:52 PM   #2
Trailer: Lil Snoozy / Jeep Cherokee
Originally Posted by Atmelanson View Post
Hi all,
I don't think the difference would be significant enough to measure unless you took the same route at the same speeds on a day with the same temperature and equal wind conditions. Even then the difference would likely be miniscule. Towing a trailer messes with the wind drag coefficient your vehicle was designed to attain. So you mustn't anticipate remarkable mpg while towing any camper.
i.e. Towing my Lil'Snoozy that weighs 800 lbs more than my previous pop up tent trailer behind my Jeep Cherokee resulted in approximately the same mpg at highway speeds. The 800 lb differential made a slightly larger difference when towing on mountainous roads.
Bill in Pittsburgh is online now   Reply With Quote
Old 04-30-2024, 02:32 PM   #3
Trailer: Shopping
New Brunswick
Ok thank you. I guess we’ve heard that Scamps are very efficient to pull and the Trilliums are boxier so possibly not as efficient. Just wondered if it would be noticeable or not.
Old 04-30-2024, 04:53 PM   #4
Scamps are only slightly more rounded in front than Trilliums. Both have a mostly flat rear end, which is bad for aerodynamics. Being very similar size and weight, I’d expect negligible difference in fuel economy.
Old 05-06-2024, 07:27 AM   #5
Trailer: Shopping
New Brunswick
Thank you for the replies!
Gas Mileage Rob M General Chat 20 11-19-2007 08:19 AM
How To Get Better Gas Mileage Patrick M. Care and Feeding of Molded Fiberglass Trailers 29 10-01-2007 03:36 PM
Ford Ranger mileage Bonnie Witt General Chat 6 01-15-2007 10:37 AM
Mileage-maintenance tracking? Byron Kinnaman Problem Solving | Owners Helping Owners 12 03-06-2006 06:49 AM
Gas mileage vs. tire pressure General Chat 0 01-01-1970 12:00 AM
