More rise vs flipping back the axel - Ventura - Fiberglass RV
Old 06-01-2020, 09:42 PM   #1
Trailer: Ventura 73’
Currently have our 73’ Ventura gutted. Since we’re in process of re doing bolts to frame - we’re considering flipping back the axel to return the trailer to original clearance. Previous owner had truck - so fits well with that hitch/drop height.
we’d be pulling with mini van (for now)... which is not even close with 6” rise. drop still towers above. Currently trying to find some safety info online. Thought I’d check in!
Cheers. V
murffie is offline   Reply With Quote
Old 06-02-2020, 10:17 AM   #2
Ventura
I put a 4 inch lift in mine it makes the bumper and the ball hight17" high no axle flip. also longer tounge.20 inches.
MAP 56 is offline   Reply With Quote
Old 06-02-2020, 10:39 AM   #3
AC0GV's Avatar
Wisconsin
No flipping
Originally Posted by murffie View Post
we’re considering flipping back the axel to return the trailer to original clearance. Previous owner had truck - so fits well with that hitch/drop height. Cheers. V
Different people mean different things when they say flipping. FLIPPING as in turning the axle over puts the curve of the axle down instead of up. This changes towing. Flipping as in just relocating the axle under the springs works fine on most units.
I'm all for returning it to factory position.
Old 06-02-2020, 11:51 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
If your trailer has brakes or if you want to add brakes, then the leaf springs need to be resting on spring perches that are welded to the axle. If you have a "straight" axle with spring perches welded to it, you can move the axle back to the original position (above the leaf springs) by rolling the axle over.
Old 06-02-2020, 12:11 PM   #5
The springs sit on top of axel currently. Putting it a lot higher than our Odyssey. there are no brakes either. Talking to service place this morning it doesn’t sound like expensive job... hour labor and $50 in parts.
I kinda agree.. nice to put it close to original. I’ll miss the clearance but maybe better for time being. Would spent service money on freaking high hitch custom order from Napa!
Thx for images. Side thought - you covered over vent on left side?
Old 06-02-2020, 12:30 PM   #6
Ventura
The left side pic was befor the fridge install .the only thing you need to make sure of is towing level ,mine has a dexter axle 4 inch blocks now it towes level at 17 inches bumper and tounge works for most cars and trucks. good ground clerance no more draging at the gas station.
Old 06-03-2020, 06:59 AM   #7
Ventura
Here is a pick of the 4 inch lift. I made mine.
ventura
Advice on Flipping Axle on 2016 Bigfoot 25B175FB rdf0011 Towing, Hitching, Axles and Running Gear 25 08-22-2018 01:56 PM
Advice wanted on Flipping Axle on 2006 Bigfoot 17.5 skyak Towing, Hitching, Axles and Running Gear 0 09-03-2012 05:46 PM
Casita high rise faucet spout Morgan Modifications, Alterations and Updates 18 02-14-2010 04:07 PM
Flipping the Axle Art Davis Modifications, Alterations and Updates 8 09-21-2007 03:52 PM
gas prices on the rise! (ranting) Christi V. General Chat 22 03-13-2007 04:44 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
