Persistent Brake Problem - 2019 Scamp 13 - Fiberglass RV
Old 11-13-2021, 11:37 AM   #1
Our Scamp 13 has the brakes and controller (Autowbrake) installed by Eveland. Everything works fine heading out, but after about 2 hours of use and when braking at < 20mph, the brakes lock up and the tires skid. No problems when braking at > 30mph.
We've been to a reputable RV repair place 3 times, and worked with Autowbrake twice. It's not a controller issue, and the controller is at the lowest setting.
Has anybody run into this?
Thanks!
ALaity is offline   Reply With Quote
Old 11-13-2021, 03:11 PM   #2
Dan Meyer's Avatar
What controller are you using?
--Dan Meyer
Old 11-13-2021, 04:40 PM   #3
Had an issue like that when we had contaminated brake pads... grease on the them. But I assume your reputable shop that looked at it three times has already removed the hubs and inspected the brakes since that basic step 1.
Old 11-13-2021, 06:01 PM   #4
--Dan Meyer
Hi Dan,
Thank you for your interest. The controller is from Autowbrake, supplied and factory-installed by Eveland (Scamp Trailers).
Old 11-13-2021, 06:07 PM   #5
Hi Gordon,
Yes, they looked at them on the first visit, and cleaned up one and resealed.
I read a post somewhere (can't find it now) that spoke of overheating and the brake needed to be adjusted. Does that ring a bell with anyone?
Old 11-13-2021, 08:01 PM   #6
Dan Meyer's Avatar
I have Tekonsha controller, so I don't know much about yours. That said, I have found that I do need to adjust the controller after the first several stops.
--Dan Meyer
Old 11-13-2021, 08:18 PM   #7
Trailer: currently shopping
My experience with your problem.
I had the same problem of brake lock up. It was with a Tekonsha "Timed" controller. Regardless of the settings, the brakes would lock up. That type controller applies current initially, then ramps it up the longer the brake is applied.
I finally changed out the controller for a "Proportional" type that matches the brake current to the deceleration rate of your stops, problem solved.
Good luck
Mr. B is offline   Reply With Quote
Old 11-13-2021, 09:02 PM   #8
Dennis mn's Avatar
Good luck
I had exactly the same experience. Never an issue with the Tekonsha Progeny Proportional controller.
2021 Nissan Pro 4X. 2020 Scamp 19’ Deluxe.
Dennis mn is offline   Reply With Quote
Old 11-14-2021, 01:37 AM   #9
--Dan Meyer
Thank you, Dan!
I confirmed with an Autowbrake technician that the controller setting is as low as it can go.
Old 11-14-2021, 01:39 AM   #10
Good luck
Hi Roy,
I believe the Autowbrake controller is proportional, but I will double-check that. Thanks for the interest!
Old 11-14-2021, 01:41 AM   #11
Hi Dennis,
I'm pretty sure the Autowbrake controller is proportional, but I will double-check that. Thanks for the interest!
Old 11-14-2021, 05:45 AM   #12
Ohio
I have an autowbrake controller on my 2019 Scamp 13. It works fine. My thought is the sensors in the controller might be messed up. Does Autowbrake have some advanced troubleshooting advice? Can you go back to factory settings and recalibrate for your install? Can they replace your controller with a new one ?
Tony D is offline   Reply With Quote
Old 11-14-2021, 10:06 AM   #13
I suggest that you go back to your manual and start your set-up over again.
There may be both a "power" adjustment and a "boost" adjustment.
That's likely where the problem is.
Unless this is what you have?....(not an endorsement of the advice below)
Old 11-14-2021, 11:39 AM   #14
Hi Tony!
Thank you for your interest and advice
Troubleshooting: An Autowbrake technician advised me to check the voltage going into as well as out of the controller. Input was >12V. The desired output is less than 1V, and my multimeter showed ~0.5V.
Recalibration: Calibration is for the unit to know what is level in terms of roll pitch and yaw (0 degrees on X, Y, and Z axes). I did recalibrate, though it is only needed when the controller is moved and remounted.
Settings: The controller is on setting 1 (for trailers <3500 lb) and gain is 0 (levels are 0-6).
Old 11-14-2021, 11:50 AM   #15
Hi Floyd - great to hear from you!
Yes, that is the controller we have (purchased from and installed by the Eveland folks, not etrailers). The controller power setting is 1 (for trailers <3500 lb) and the boost is 0 (levels are 0-6). So it's at the lightest setting, and all indications are the controller itself works fine.
Old 11-14-2021, 12:06 PM   #16
Did you adjust the brakes?
As you likely know, I am considered by some to be a Luddite on this subject, but I prefer my tow vehicles to be equipped to tow.
Every new thing is not necessarily an improvement.
WARNING... It is not wise to wire brake power to a lighting circuit.
There are good alternatives.
Old 11-14-2021, 12:31 PM   #17
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
Did you adjust the brakes?.
I'm also in the Floyd camp on this.
It seems like you might have the mechanical portion of the brakes adjusted too tight.
Take a peek at some youtube videos on how to mechanically adjust the brakes and see if that helps.
AlanKilian is offline   Reply With Quote
Old 11-14-2021, 11:01 PM   #18
Hi Floyd,
No, I haven't adjusted the brakes (yet). Not something I'm familiar with, but definitely the next step I was leaning toward. I was hoping to find specific guidance on how, so I think I will call Scamp to see what brakes they had put on, so I can find the appropriate how-to video and tool. That or find a place that works on simple flat-bed trailers and let them do it.
Old 11-14-2021, 11:05 PM   #19
Thank you, Alan! Two votes now for mechanically adjusting the brakes. Seems like the way to go!
Old 11-15-2021, 09:23 AM   #20
Brake adjustment is fairly simple.
Here is a video which might help.
A couple of points not covered...
1] You can check your progress by spinning the wheel but it is not necessary to keep it spinning through the whole process.
2] Your brakes may have two access ports or it may only have one.
3] The video assumes that the brakes are loose, start with the wheel spinning freely, then tighten as shown.
WA | 2019, May 31-June 2: Taidnapam Washington Gathering (WAG) 2019 Possum Rallies, Get-togethers, Molded Meets (Archive) 50 06-20-2019 11:39 PM
WA | 2019, May 17-19: Maryhill in May 2019 paulw Rallies, Get-togethers, Molded Meets (Archive) 31 05-21-2019 10:48 AM
NH | 2019, May 16-20: 2019 Spring Fling in New England Gerry Rallies, Get-togethers, Molded Meets (Archive) 127 05-20-2019 03:31 AM
AZ | 2019, Feb 4-10: Quartzsite Gathering 2019 Greg A Rallies, Get-togethers, Molded Meets (Archive) 137 05-15-2019 06:26 PM
