01-17-2013, 11:14 PM
Trailer: 1979 Scamp 16 Delux
Raising a Compact II
This may go against the grain but I would like to see any photos of Compact II, or Jr, units that have removed the drop axle and replaced it with a straight axle and perhaps increased the size of the wheels.
My shop has twelve foot doors so no clearance issues for me.
I will also keep all the original parts so someone will have the option of putting it back to normal.
My unit is a 1974 Hunter I Compact II and it doesn't have a front window rock shield. I will also need some instructions on placing a photo within the text, so others can see my progress.
Dave Heffner
Roseburg, OR
01-18-2013, 12:02 AM
First off Dave, welcome! Your trailer is one that several other members have. I don't have any wisdom on that score, I am kinda a Trillium fanatic.
I can however help with basic photo posting. When you created this thread, there was a button below the text entry area labeled "Manage Attachments". When you press this it opens another window. From this window you can select files to upload. Pictures four at a time, ten in total, per posting. Movies too. When you have selected the files, push the upload button that is in the box the file path is in.
The "Manage Attachments" button is not available when you use the Quick Reply box, but if you push the "Go Advanced" button below the text entry box, you will have it.
01-18-2013, 10:57 AM
Thanks for the response David. I'm looking over this REPLY format and not seeing anything except the 'Add Video' below the text.
Along the toolbar there is picture titled 'Insert Image', I'll play with that.
If this works, this is my previous Compact II with a flipped axle.
Okay, I'm on my way.
01-18-2013, 03:25 PM
Trailer: Compact Jr.
Dave, I am in the process of a frame off resort on a Compact jr. I have done exactly what you are thinking of doing. I replaced the axle with a straight axle, 3500# with 1250# leaf springs and 15 in. tires.
The reason I went with the 3500# axle it was the only one I could find locally with 5 lug hubs and break flanges.
There seem to be plenty of run in the wheel wells to accommodate the mods. (6 in. Above tire and 2 in. Front and back)
01-18-2013, 03:38 PM
Sorry, plenty of room
My plans are if I have to go to a 14 in. tire I have a utility trailer that the 15's will fit.
I didn't measure the frame heights but am guessing it raised it between 5-6 inches.
01-18-2013, 09:21 PM
Tim, thanks for the pictures. I have always felt that the Jr. was just a little bit larger looking than the Compact II. What size tires did you use?
I like what you have done. We might have the same reasons for some extra ground clearance. But, did you notice any more stability from that side-by-side swaying that the original axle, springs, and tires give?
Here is my project:
01-18-2013, 10:08 PM
Trailer: '78 Trillium 4500
Per sway:
If you're talking about "oscillation", aka "tail wagging", it tends to get worse the more you raise the trailer/center-of-gravity.
Stiffer suspension may result in less bounce, though.
Francesca
01-19-2013, 12:21 AM
Francesca, the trailer seemed to track behind the truck pretty well, when I brought it home. The trip was about 25 miles. However, I did notice that it would rock when one wheel would go through a low spot at low speed.
Today when I was starting to clean off the moss it seemed to rock quite a bit as I scrubbed. I'm hoping that the 13" tires are radial and probably not true trailer tires. I'm going to look into some 6 ply rated tires, plus new axle and springs.
I guess I rocked a little when I was 40 years old.
My previous Compact tracked pretty well with the axle flipped, but I was always worried about the ground to axle height.
01-19-2013, 05:05 PM
You're smart to start with tires- when I got my Trillium it had spankin' new "P" tires on it, and at that time I had no idea there was any difference among types. First time I got it up above 40 mph it swayed like crazy. I thought I needed a "sway controller" or something, but when I went to my local RV guy he took one look at my tires and told me that the only thing I really needed was to get those passenger tires replaced with bias-ply ST's.
An honest guy voluntarily giving up a sale...permanently, as it turns out! I went straight to Les Schwab and did as he advised. 40,000 tow miles later I STILL have no mechanical sway control, nor will I ever. (Maintenance side note: I've just begun on my third set of ST's...I'm very much a fanatic about replacing them at the proper intervals whether they look like they "need it" or not.)
The while-stationary "wiggle" you describe may just be normal- my Trillium is pretty soft that way, too. But in my case at least, it doesn't affect enroute trailer stability. That's more a function of the corrected tire type (properly inflated for the load), the right tongue weight number, trailer loading, and speed. Speed can't be overemphasized in its importance for preventing sway, which almost always begins as one approaches/goes beyond about 50-60 mph. Every tug/tow combination has its "sweet spot" in that department and with time you'll find yours...
Per ground-to-axle height, if you're talking about being off-pavement (Forest Service roads etc.): I've found that the sheer smallness of my setup solves that problem very neatly. The rig's so narrow that I can drive such roads with one wheelside on the center hump, and one side on the shoulder. That not only increases the clearance between my "underbelly" and the ground by placing it over the deeper ruts, it puts my wheels where most of the gravel is!
Of course, one must be prepared to accept that both tug and tow may come home from the adventure with the badge of honor known as a few "Sierra pinstripes" along the sides. But they haven't broken through the paint/gelcoat yet, so no problem as far as I'm concerned...
Francesca
01-19-2013, 09:02 PM
'Sierra Pinstripes' that's a hoot.
I hope to have enough miles to someday say I'm on the third set of tires. A true merit badge for your dedication.
Dave Heffner
01-19-2013, 09:11 PM
Whereabouts in Oregon do you call home, Dave? I'm an Oregonian by birth and am just curious. Though I now live in Washington I've camped all over my beloved Home State.
In fact, I wouldn't be surprised if some of my pinstripes were "earned" somewhere near you...
Francesca
01-19-2013, 09:26 PM
I'm 10 miles west of Roseburg, in a community called Melrose. There is a wonderful RV campground near us called Twin Rivers.
My wife and I used to travel through Roseburg on our way up to Toledo, Washington with my folks, going to a family reunion. My mother's cousin lived on the Cowlitz River.
I knew right away where I wanted to retire. However, right now the high in Roseburg was 37 degrees, and that makes working on the trailer a little hard.
01-19-2013, 09:35 PM
I had "flipped" the spring mounting on my Compact Jr's original axle.
Even though the drop axle itself stayed low, I never really towed it on deeply rutted roads so I'm not aware of any issues high center scraping the axle would have. Mine was a solid square bar, so I felt it could take minor impact.
I'm in the process of a total frame-off rebuild. My new axle is hollow round tube with 7" brakes, rated for 2200 pounds. I couldn't put brakes on the old axle.
01-19-2013, 09:46 PM
Roseburg!
Oh, yes- We've camped along the Umpqua River a time or two. You'll know where by the busted branches alongside the F.S. roads- sorry about that!
Good luck with the project, once the weather warms up enough to get back to it...
Francesca
01-19-2013, 09:56 PM
Hi Frederick, what size wheels and tires are you going to install on the new axle? Also, are you going to make a straight axle for the Jr.?
I was at the tire shop today looking at wheels and tires. I expect to raise the unit about 5" in total. How hard is it to pull the frame out? Do you raise the body away from the frame, slip in a 4x4, block up the beam, remove the wheels, and pull it out? Is the fiberglass body/plywood floor strong enough to start the lift?
01-19-2013, 10:22 PM
- what size wheels and tires are you going to install on the new axle?
- are you going to make a straight axle for the Jr.?
- How hard is it to pull the frame out? Do you raise the body away from the frame, slip in a 4x4, block up the beam, remove the wheels, and pull it out?
- Is the fiberglass body/plywood floor strong enough to start the lift?
- I'm staying with the original 13" wheels
- No. I had a drop axle made with the same 4" drop. My goal is to keep it as light as possible with a low frontal area to tow behind my 2005 Pontiac Vibe. That's why brakes were necessary.
- I stripped the body down to just the fiberglass shell. Took the top off. Pulled the interior out, removed the windows and door, and pulled the floor up and out the door opening. Removing the floor also disconnected the body from the frame, the same bolts hold both. With nothing but fiberglass left, had one person at each corner lift the body up off of the frame and the 4 of us walked it over and set it down beside the frame.
- I wouldn't lift the fully assembled body, but man-handling just the fiberglass by itself is easy.
01-20-2013, 08:49 AM
I used 15x5 wheels and tires are Carlisle ST.205/75R15.
As far as body roll I can't comment being I haven't attached the body to the frame.
As Frederick stated removing the shel from the frame requires gutting the interior and floor removal.
The reason I raised mine was my tv is a 4x4 full size truck and it just didn't look rite in my opinion with little tires plus axle to ground clearance was a concern.
01-20-2013, 09:27 AM
Trailer: Casita 17 ft Freedom Deluxe 1998
Tim and Frederick,
I'm so glad to be watching this thread, since I have plans to significantly spruce-up our recently acquired Compact II.
I know that I definitely want to remove the frame from the body so I can clean, inspect, and repair the frame (as needed), and to "flip" my axle to gain some towing clearance. Is gutting the interior a "must do" in order to separate the frame, or can the frame be "dropped" from a trailer that is carefully blocked-up like I have seen others post for Scamps, Bolers, etc.
My trailer has a fridge, toilet, water tank, demand pump, etc.
Thanks,
Bret
01-20-2013, 10:09 AM
Bret,
Based on what it took to remove my shell from the frame, I wouldn't attempt to separate the two without removing the interior. The location of the frame bolts would prevent this.
What type of frame repair are you talking about? The axle could be flipped by jacking and blocking the whole unit up and removing and reinstalling the leaf spring.
01-20-2013, 11:04 AM
Thanks for the information about the body lift. My project is not going to be a complete frame off. I was afraid it was going to be too much of a challenge to get the existing bolts back into the frame and aligned straight. However, my tongue area and back bumper are in need of sandblasting, so I will see how close we can get to the main body and repaint. Even the safety chain is in need of replacement.
Here is the tongue area now:
Raising 84 scamp by 2 in.
thunter |
7 |
07-12-2012 06:22 PM |
Raising one bench
Dave Bese |
1 |
05-27-2010 10:21 PM |
Raising 17' Boler
sarah j |
0 |
06-10-2009 03:17 PM |
Raising a Bigfoot
Peter DBK |
16 |
09-09-2008 05:06 PM |
Raising a Casita SD16
Steve Rosenberg |
8 |
11-26-2005 11:54 AM |
