Replacing Trillium Body Bolts - Fiberglass RV
Old 11-01-2021, 03:23 PM   #1
I am replacing my axle on my 1980 Trillium 4500, it has no suspension left in the torsion bars. I talked to the installer for a Dexter axle and he noticed 3 of the rear frame to body (shell) bolts have loosened and are rusty. He is not really willing to put this on a hoist because he is afraid the spring in the frame may stretch and snap the bolts. I can cut them off if needed but does anyone have experience finding and replacing the bolt heads inside the trailer? They are at the corners of the rear subframe, so I think they are likely inside the cabinets or storage areas under the bed.
Thanks, Tom
Thomas W is offline   Reply With Quote
Old 11-01-2021, 04:27 PM   #2
David Tilston's Avatar
Tom, In a Trillium 4500, there are eight bolts. Two each in the rear dinette seats and though I have never personally seen a front dinette Trillium, or almost dinette, (that is what you should have) there should be two bolts in each of the front dinette seats. They will have a large square washer.
Typically these are rusted right through, or nearly so. You will need someone in the trailer to hold the head of the bolt with a pair of vice grips, and someone underneath with a big wrench, (or impact). The frame bolts are one of five maintenance items on an old Trillium.
The others are:
Wood in the window frames
Re-hang door
Belly band repair
Replace axle, (you are already on this one)
Old 11-01-2021, 06:56 PM   #3
Trillium Body Bolts
Thank you David, this is exactly what I was looking for. I do in fact have a front dinette, so I will likely replace those bolts while I'm at it. I do have some large hand tools and breaker bars so I think I'll be able to unscrew or twist them off.
Old 11-01-2021, 07:09 PM   #4
Trailer: 2013 Escape 19
My bolts were the “special” Trillium quick release design. Put a wrench on the bottom, then gave it a quarter turn and SNAP. There was about a pencil lead worth of bolt remaining.
Old 11-01-2021, 07:21 PM   #5
The others are:
Re-hang door
Belly band repair
Old 11-02-2021, 06:38 AM   #6
Indiana
Great guidance above. As I recently went through this myself with our 1978 4500, I would add:
-Make certain that the plywood is intact in the area around the bolts. The fact that they are loose would concern me that there may be dry rot. I had to replace the plywood under one of my back bunks, not an easy job, but necessary to have the fiberglass shell secured to the frame.
-I used stainless steel replacement bolts to reduce risk of corrosion. I considered galvanized which would be more economical.
Steve Hague is offline   Reply With Quote
Old 11-02-2021, 06:59 AM   #7
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Ditto on my Trillium 4500: Replaced the rusted out fasteners with stainless steel hex head bolts, ss nylock nuts and 3"x3" galvanized backing plates.
Old 11-02-2021, 07:05 AM   #8
Raz
Raz's Avatar
While lubricating my stabilizers this past spring I noticed the nut on one of my body bolts was loose. Further inspection found 2 more. Being stainless there's no rust so after 11 years they had vibrated loose. I guess nylocks or thread locker would solve the problem. For now I just tightened them. I'll check them in the spring.
Old 11-02-2021, 08:08 AM   #9
no cracking the shell
++ for nylock nuts, the other thing I like about using nylock nuts when bolting through the fiberglass shell is that I don't have to tighten down so tight that the shell starts cracking. So I've been using nylock nuts extensively those applications. I used them when replacing all of the fasteners holding the cabinets and benches to the shell in Boler 17, and of course with the body to frame bolts. Have also used for attaching exterior fixtures, towing lights, ... No cracking the shell.
trillium
Trillium Body Mounting Bolts Larry C Hanson Problem Solving | Owners Helping Owners 4 01-15-2021 01:33 PM
Trillium 1300 body mount bolts Gullygossner Problem Solving | Owners Helping Owners 11 10-06-2019 01:53 AM
Bigfoot 17 replacing body-to-frame bolts Tim D. Problem Solving | Owners Helping Owners 2 09-21-2015 09:58 AM
Check your body bolts Craig D. Thompson Care and Feeding of Molded Fiberglass Trailers 11 08-04-2015 12:54 AM
Bolts .... frame to body Roland H Problem Solving | Owners Helping Owners 6 09-11-2010 09:08 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
