Rims for a Trillium 4500 - Fiberglass RV
Old 05-18-2012, 02:26 PM   #1
David Tilston's Avatar
The wheels on my Trillium 4500 are on 13" rims. I have heard that Ford Ranger wheels fit, but they are all 15" rims. Can anyone confirm if 15" rims will work, and what tire size they use.
Old 05-18-2012, 02:45 PM   #2
All the "Frod Danger" rims I have seen are 14 inch - its what I have on my Bigfoot 21 trailer. Bolt pattern is 5 bolts on a 4.5 inch bolt circle - known as "5 on 4-and-a-half" They also fit perfectly on Boler 17"s.
Old 05-18-2012, 03:05 PM   #3
Roy in TO's Avatar
Originally Posted by BCDave View Post
All the "Frod Danger" rims I have seen are 14 inch ... Bolt pattern is 5 bolts on a 4.5 inch bolt circle -
My Ranger has 15's with the same bolt pattern.
Old 05-18-2012, 03:24 PM   #4
Thomas G.'s Avatar
Just to clarify, 5 lugs on a 4.5" bolt circle is a standard rim. It shouldn't be hard to find at all, unless you need a unique offset.
Trailer Wheel and Tire Assemblies.
Old 05-18-2012, 04:21 PM   #5
KevinWA's Avatar
Trailer: Trillium 4500 1978
the new trill can be ordered with 14 inch wheel package for "off road"........does anyone know what size the "off road" tire is on the new trills?
i am running st175 13 wagon wheels .i would like to see or try a set of 14" trailler wheels just to fill the wheel wells a bit better..the bolt size is called 5 x 4.5....this is the same patten as ford rangers and a lot of jeeps.
KevinWA is offline   Reply With Quote
Old 05-18-2012, 07:34 PM   #6
Trailer: One 13 ft Scamp and One 13 ft Trillium and Two Trillium 4500
Rangers came with 14", 15" and even 16"...I've got 6 Trilliums and put 14" aluminum ranger wheels on all of them and never looked back...The tires are easier to find and gives a little more ground clearance...Don't think 15" rims would work.... mine are very close fit as is but have never had them to rub yet and I've been over some very rough roads..Here's 4 of mine so you can see the clearance...Note that the 14' rims are harder to find because that were only used a few years and people snatch them up to put on boat trailers and utility trailers..guy at the junk yard told me that they don't set around very long because they can be used on so many trailers....also note that they come in two different styles one is called the Bullett Hole Rims and the other is called the Deer Print Rims
Randy Bishop is offline   Reply With Quote
Old 05-18-2012, 08:01 PM   #7
Trailer: 1978 Trillium 4500
Nice set you have there Randy
Cheers
--Fred and Natalie
1978 Trillium 4500 "Bernerwagon"
freddo411 is offline   Reply With Quote
Old 05-18-2012, 08:25 PM   #8
Thanks...... alot of hard work in those.......................
Old 05-18-2012, 08:43 PM   #9
floyd's Avatar
Although they may work in some trailer applications, Ranger wheels have various offsets and most trailer wheels are 0. Also most stock Ranger wheels are 1-2" wider than most trailer wheels.
The Trillium design is open, but these rims might present problems for something like a Scamp.
BTW; It took a moment for me to realize that those who don't recognize the best truck and best truck value ever built, would have difficulty spelling it's name properly!
Without checking, I'm thinking you would have to go back more than a decade to find stock 14" rims from a Ranger.
Old 05-18-2012, 10:03 PM   #10
KevinWA's Avatar
i sure do miss my 97 shot box(step side), reg cab, 4 cyl, 5 sp truck with 235 60 15 tires factory chrome wheels......not enough power, always stuck in the snow.....but great on gas..........this might just be the bump i need to get the 14s on the trill.
trillium
Rims on a Trillium Randy Bishop Modifications, Alterations and Updates 32 04-11-2016 10:46 AM
14" Rims on a Trillium Tim Ryce Towing, Hitching, Axles and Running Gear 10 04-14-2011 07:27 PM
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin Classified Archives 13 03-06-2011 08:27 AM
1979 Trillium 4500 for sale -- C$5200 or US$4500 - SOLD jenniferm Classified Archives 8 07-14-2009 01:38 PM
