Scamp 13. Towing with furnace on. - Fiberglass RV
Old 04-23-2021, 03:18 PM   #1
Trailer: scamp 13
I have a pretty new Scamp 13 with the built-in furnace. This is a really naÔve question. I wondered, when I am relocating from a day spot to a night sleeping spot, maybe traveling 3 miles or so, is it OK to turn the furnace on and have it on while Iím towing for 10 minutes or so? That makes things cozy and saves a little battery, since the furnace fan can run off the alternator then. Plus the furnace is kind of noisy and it itís nice to have it off as much as you can.
zack sc is offline   Reply With Quote
Old 04-23-2021, 08:00 PM   #2
IllAnnoy
That is an interesting idea.
Something like 75% (according to several polls) travel with the propane on to run the fridge.
There is no obvious reason why this would not be similar or perhaps even a bit safer.
Driving with the water heater on has been known to blow out the pilot light and shut down the water heater, occasionally it can even happen to the smaller fridges.
The furnace works fine in high winds when parked... and it has no pilot.
I personally don't make a habit of running propane when towing, but those issues don't directly relate to furnace operation.
Old 04-24-2021, 10:35 AM   #3
Propane furnace on while driving
This may present a problem on a Scamp trailer. The furnace intake is located on the side of the trailer and when driving, the air movement across the trailer creates a negative (vacuum) pressure. This in turn can make the flame go out.
If the flame goes out it should attempt to reignite.
Personally I make it a practice to shut the propane off while driving.
Monk is offline   Reply With Quote
Old 04-24-2021, 10:37 AM   #4
Trailer: Trail Cruiser
If your trailer is warmed up and you shut off the furnace for 10 min to move and then turn the furnace on again, will your unit get that cold in 10 min? In some locations, towing a trailer with the propane tanks open is prohibited as an open propane tank could vent should an incident like a detachment etc. occur.
Old 04-24-2021, 11:23 AM   #5
Being Safe than Sorry is the answer.
Old 04-24-2021, 11:24 AM   #6
Source of this information please. A link that can be used to confirm.
Old 04-26-2021, 08:20 AM   #7
Alex Adams's Avatar
Trailer: 1979 Boler B1300
New Hampshire
Chesapeake Bay Bridge and Tunnel:
CBBT Compressed Gas Regulations
Old 04-26-2021, 08:43 AM   #8
Right, and gas stations and ferries, but not highways.
Old 04-26-2021, 09:26 AM   #9
In Virginia you must stop and an official will confirm that your tanks are OFF B 4 you are allowed to go through tunnels.
Old 04-26-2021, 10:46 AM   #10
Trailer: Casita 16 ft
I have pre-warmed the trailer any number of times, stopping a few miles before the campground, turning on the heater and trailer is warm as I enter. Never had a problem with it.
Fan forced air furnace should be ok, but there are possibilities of something going wrong. Running off the road is a much larger worry.
If you are in the trailer you might be able to fix the situation before it gets out of control. (Looking in side mirror and seeing a large fireball following you.)
The newer trucks with a 2000 watt generator built in would be good for running the AC to get the trailer pre-cooled on a hot day.
Friz is offline   Reply With Quote
Old 05-01-2021, 03:00 PM   #11
Ohio
I can understand running the fridge on the road, although ice is cheep. I think running the furnace on the road is ... not a good idea. Iím slow in making camp, but if I were to turn it on once I arrive, my little Scamp will be all toasty by the time Iím ready to put on my PJs.
Tony D is offline   Reply With Quote
Old 05-01-2021, 07:34 PM   #12
Originally Posted by Tony D View Post
I can understand running the fridge on the road, although ice is cheep. I think running the furnace on the road is ... not a good idea. I’m slow in making camp, but if I were to turn it on once I arrive, my little Scamp will be all toasty by the time I’m ready to put on my PJs.
That’s a good point. Unlike the fridge, which is ve-e-ry slow to accomplish its mission, the furnace heats up the Scamp in a jiffy.
Given the relatively poor insulation of the Scamp, most of the heat put out while you’re towing would be wasted anyway.
Old 05-03-2021, 08:00 AM   #13
Trailer: 2015 Escape
Thatís a good point. Unlike the fridge, which is ve-e-ry slow to accomplish its mission, the furnace heats up the Scamp in a jiffy.
Given the relatively poor insulation of the Scamp, most of the heat put out while youíre towing would be wasted anyway.
When driving (towing) from Michigan to Arizona to spend the winter and leaving home in December I kept the furnace going at a reduced setting. Without heat and driving for several hours in cold weather itís not pleasant to hit the sack in a cold bed.
Old 05-03-2021, 09:16 AM   #14
I could see that in your situation, especially if you unwinterize the trailer for the trip south. Youíd need some heat for the pipes as well as your comfort. I believe you have an Escape, perhaps with the winter upgrades? That makes it a more practical proposition.
Old 05-03-2021, 10:04 AM   #15
IllAnnoy
Agree, warm air in a few minutes, but pull the covers back or put a hand under a pillow!!
furnace, scamp
I am looking for a gravity furnace (old style furnace) fred wark Care and Feeding of Molded Fiberglass Trailers 17 03-14-2021 09:13 PM
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 49 06-19-2019 02:27 PM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Furnace or No Furnace Crackedegg Problem Solving | Owners Helping Owners 7 09-09-2012 07:30 AM
