Scamp 16ft dry vs unloaded weight - Fiberglass RV
Old 02-20-2022, 01:09 PM   #1
Trailer: scamp
west
Hi
I need some help.
I'm selling my 16ft scamp (layout 4) side bath and trying to get the weight of the trailer in the right range, 1,800 to 2,000. Listing it as unloaded weight VS dry weight would be more accurate. Do you guys agree. Do I need to add more.
I looked at what you guys have listed and the weights with them fully loaded which is helpful. They're coming in around 2,400lbs.
Thanks for any insight.
Outwest Scamp is offline   Reply With Quote
Old 02-20-2022, 02:43 PM   #2
I think the unloaded weight with battery and propane but empty holding tanks would be most useful. But I wouldn’t list anything in the ad unless you have actually taken it to a scale. Guesstimates aren’t helpful. If they ask about weight and you don’t have a scaled number, you might give a typical loaded range of 2400-2700#, based on the database.
I appreciate your commitment to honesty. Whether intentionally or through ignorance, I’ve seen a lot of gross understatements of trailer weights in ads.
Old 02-20-2022, 10:24 PM   #3
AC0GV's Avatar
Wisconsin
RV weight on a CAT scale
I think the unloaded weight with battery and propane but empty holding tanks would be most useful. But I wouldn’t list anything in the ad unless you have actually taken it to a scale. Guesstimates aren’t helpful. If they ask about weight and you don’t have a scaled number, you might give a typical loaded range of 2400-2700#, based on the database. I appreciate your commitment to honesty. I’ve seen a lot of gross understatements of trailer weights in ads.
I’d get everything not included in the sale out of it and run it over a scale. The new owner will thank you. Even Scamp gets the weight wrong, my published shipping weight was 600 lbs light. Towing requires the knowledge of three weights, axle, hitch and total. It’s worth the cost to know. Cat scales will have multiple platforms, get the hitch on one and the axle on another. I think CAT rounds UP to the next 20 lbs. (picture is as picked up, no water full LP)
Old 02-21-2022, 08:40 AM   #4
Trailer: scamp
west
Thank you for the response. Changed ad.
In my scamp manual it says dry weight for 16 is 1550 lbs, which is lower than the approx. 1750 to 2000lbs. I had read somewhere that the older scamps weigh less.
Thank you
Old 02-21-2022, 08:52 AM   #5
Thank you
Almost everything is technically optional on a Scamp. Fridge, optional. Toilet and shower, optional. Water heater, optional. Battery, optional. Awning, optional. Furnace, optional. Air conditioner, optional. Extra cabinets, optional.
Published dry weights are for the base, unoptioned model. Actual unloaded weights as built can be hundreds of pounds heavier. Older Scamps can be a bit lighter, yes. It’s partly because they used different frame, floor, and window components, and partly because the option list has grown over the years. Owner modifications also factor in.
New or old, the only way to know the weight of yours is to visit a scale.
scamp, weight
Not seeking a dry county but we are now dry BatDude Problem Solving | Owners Helping Owners 6 12-24-2015 03:48 PM
trillium 5500 dry weight ? mmaclean Problem Solving | Owners Helping Owners 11 08-20-2014 11:24 PM
Dry Weight Required Dallas, B Problem Solving | Owners Helping Owners 3 06-05-2008 09:02 PM
Dry Weight?? Donald L Problem Solving | Owners Helping Owners 2 05-21-2008 08:32 PM
trillium dry weight franklin hammond General Chat 8 07-08-2007 08:53 PM
