Snoozy brake size? - Fiberglass RV
Old 09-13-2021, 12:14 PM   #1
Trailer: 2014 Lil Snoozy
MN
Snoozy brake size?
Any Snoozy owners know what size brake drums are on the Lil Snoozy travel trailer. I smoked a wheel bearing and the brake on left side is shot. I have a 2014 Snoozy with "Tie Down" brand brakes and thought maybe I could get parts sorta locally in Minnesota. It is a drum, not disc system.
Thanks, Don
roadfossil is offline   Reply With Quote
Old 09-13-2021, 02:12 PM   #2
A good place to start is to crawl underneath and find out what axle they put under your trailer. There are many different axles out there, and they all make several different configurations of each. Write down any numbers on the axle id plate, if it still exists, and get some dimensions as well for help with your research.
Old 09-13-2021, 02:23 PM   #3
Does the Snoozy have surge brakes ? I was thinking they were built on a boat trailer frame.
Old 09-13-2021, 02:24 PM   #4
sokhapkin's Avatar
SW Florida
Most likely you have 10" brakes. But like Greg said - get a tape measure and crawl under your trailer.
Sergey
www.callwithus.com
Old 09-13-2021, 02:37 PM   #5
MN
Yes the Snoozy has surge brakes and is built on a boat trailer.
Old 09-13-2021, 03:57 PM   #6
I would guess they are 10". Check at Eastern Marine and etrailer.
Old 09-15-2021, 12:51 AM   #7
David B.'s Avatar
When I ordered our 2014 Lil Snoozy one had a choice of surge disc, surge drum or electric drum. I opted for the surge disc brakes, and they have turned out to be the best trailer brakes I have ever had.
Old 09-15-2021, 07:44 AM   #8
Trailer: Scamp 19
SW shore Lake Erie In Cattaraugus County
Take it to a good trailer shop and let them do it. If you don't know how to figure out the right size of brake, you don't know how to properly replace them.
parmm is offline   Reply With Quote
Old 09-15-2021, 08:15 AM   #9
Name: You can't call me Al
Massachusetts
Hey there, let's try to be encouraging and helpful.
They asked if someone KNEW the size of the brakes on their trailer to make getting the right parts the first time more likely.
I love to see people learning new stuff, and this is the kind of thing that would have been left to the family 10-year old to deal with in our farming past, so it's not that difficult to learn and perform correctly.
To the original poster, please keep us up-to-date on your progress.
Photos and success reports help everyone get jazzed up about tackling something they have been putting off.
AlanKilian is offline   Reply With Quote
Old 09-15-2021, 10:06 AM   #10
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Latter Snoozys are not on a boat trailer
Early Snoozys were built on a boat trailer frame. The later models have a custom built frame with a rectangular perimeter and some bracing for the grey tank. They are welded, hot dipped galvanized and utilize leaf spring suspension with surge brakes. I don't anticipate a frame rusting issue with my trailer for many decades.
Old 09-15-2021, 12:58 PM   #11
MN
Just trying to round up parts so the trailer doesn't sit for a week or two at the local mechanic's shop waiting for parts. Town is around 700 population.
So far the surge brake assembly brand appears to be a "Tie Down" drum brake model with 10 inch drum. (Ouch! my 72 yr old arthritic knees hurt from crawling under trailer) Eastern Marine's "Trailer Parts Superstore" proved to be a valuable resource for finding parts. Based on info from other sites, I think I will have new brake assemblies installed on both sides.
Thanks to all for the advice.
Old 09-15-2021, 01:09 PM   #12
MN
In the FWIW department, the bearing failure and brake damage occurred 770 Miles and two traveling days after it was inspected and repacked by a reputable trailer shop, on the Sunday before Labor day. A shop in rural Wyoming was able to replace the bearings and get me on the road the Tuesday after labor day, less the damaged and removed drum brake parts. Didn't want to wait in rural Wy for an indeterminate time until parts were ordered and arrived. No problems on the return trip, didn't really notice much difference with no left trailer brakes.
Don
Old 09-15-2021, 01:09 PM   #13
CarlD's Avatar
Trailer: LiL Hauley
Syracuse, NY
Interesting that you want to have new brake assemblies. I have heard of owners of electric brakes replacing everything. Drum brakes are the same as car drum brakes without the park brake stuff. Why would you not just replace the shoes?
Old 09-15-2021, 02:07 PM   #14
MN
I had to limp the Snoozy in about 7 miles to nearest cellular service. These was no cell service where I discovered bearing out. Perhaps the wobbly wheel from broken bearings and hub damaged the shoes and assembly. The hub was also broken. The shoes were loose side to side, had delamination on some areas near the corner, and they had to be removed to avoid rubbing after bearing and hub were replaced. All parts covered in a newly baked on hardened grease coating from heat generated. I believe they sell the brake assemblies in pairs, so thought this would be a good time to replace both sides. Happened on Hwy 85 between Bowman ND and Midwest WY. Lots of rolling hills and valleys.
Don
Old 09-16-2021, 08:27 AM   #15
Most likely because the entire brake assemblies are easier to source than the shoes alone, and also with very little difference in price.
In addition to the shoes, one should change the magnet, add all of that up and you are at the price of the whole assembly.
Charles
'03 Ram 2500 CTD and 2008 Bigfoot 25B21RB...... My Thor/Dutchman Freedom Spirit 180 is being repaired and will be sold. Long gone now is a 2007 Winnebago View 23H Motorhome.
CharlesinGA is offline   Reply With Quote
Old 09-16-2021, 11:00 AM   #16
Charles
Post #5 states they are surge brakes, not electric, so no magnet
But when replacing electric brakes it is easier to replace the whole assemblies that does include the magnet. Did it on our Casita.
Old 09-16-2021, 11:11 AM   #17
Trailer: Lil Snoozy / Jeep Cherokee
I, too, have the surge/disc set-up and agree they are very good under most conditions. I have also found them to be almost useless under slippery conditions when slowing the tug is not working and obviously not applying back pressure to activate the surge brakes.
If I ever replace my axle I will be changing to an electric set-up providing some chance of activating the trailer brakes in less than optimal conditions. Even minimal help would be better than none at all.
I have also found that I need brake replacement approximately every 25k tow miles which is more frequent than I initially thought would be necessary.
Bill in Pittsburgh is offline   Reply With Quote
Old 09-18-2021, 03:24 PM   #18
Four years ago I replaced the Chinese bearings and seals with American made bearings purchased from local bearing store. It’s been many miles now I do not bother repacking every few thousand miles. They run cool to the touch. We did not service wheel bearings on passenger cars years ago and I don’t see a need to repack off they are not being exposed to unusual conditions.
barrry smithe is offline   Reply With Quote
lil snoozy
brake-1999 casita 16" ft. electric brake koy Problem Solving | Owners Helping Owners 2 07-23-2018 05:47 PM
To brake or not to brake that is my question PrettylilTrilly Towing, Hitching, Axles and Running Gear 36 04-23-2015 08:51 AM
Brake Controllers on cars that might brake automatically boley Towing, Hitching, Axles and Running Gear 40 09-06-2013 07:47 PM
Brake pedal switch - Brake controler Dave Mac Problem Solving | Owners Helping Owners 13 07-19-2007 07:49 AM
Electric Brake or Surge Brake? Bonnie Barge Problem Solving | Owners Helping Owners 28 08-28-2006 01:44 PM
