Sourcing axle for Trillium 1300 - Fiberglass RV
Old 01-19-2022, 04:28 PM   #1
WA
Hello all,
I'm looking for an axle for our 1974 Trillium 1300. I think I prefer Flexiride, but will consider Dexter. Having trouble finding Flexiride anywhere due to pandemic supply chain issues. Does anyone have a good source for either axle?
Cheers!
esgarbanzo is offline   Reply With Quote
Old 01-20-2022, 01:36 PM   #2
Trailer: 1976 Trillium 1300
I cannot help with suggestions for a replacement torsion style axle. I know that I had difficulty sourcing a torsion axle from any source about five years ago.
Just a thought, I replaced my original torsion style axle on my 1976 Trillium with a Dexter leaf spring axle. I've been very happy with the leaf spring axle, it rides very smoothly and was much more cost effective than the torsion- cost including welding new mounts on the trailer frame was about half what a torsion axle would have cost. The axle also has the added benefit of being easily field repairable of needed with easy to find replacement parts.
What I did was purchase a 3500Lb axle, but Mounted it on 2000Lb slipper leaf springs. This gets me the heavier duty axle with larger brakes, but keeps a smooth ride. A leaf spring axle will raise the ride height slightly vs a torsion axle, but Using slipper style springs minimizes this ride height increase.
The leaf spring axle might not be for everyone, but just wanted to mention that I've had great luck with mine and like it better than my experience with torsion axles.
Darryl_Lowes is offline   Reply With Quote
Old 03-08-2022, 06:48 PM   #3
WA
Hello again,
Thanks for the input Darryl. With no professional help nearby I found a flexiride supplier who will ship the axle. I have it on order now. I got some help from Canadian Axle with dimensions - 48" to outer bracket and 64" hub face.
I was hoping to confirm with folks that they've used these dimensions successfully. They're pretty difficult to get with the trailer intact.
Thoughts? I saw on restomod post on here where he was going with a 65" hub face. Perhaps the extra width would be nice.
Cheers
Old 03-09-2022, 09:10 AM   #4
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
Originally Posted by esgarbanzo View Post
Hello again,
For my 1977 Scamp 13' I got a Flexiride from Canadian Axle with the following dimensions:
OB: 48.375 Outside Brackets
HF: 63.25 Hub Face
12-degree down
and it's just PERFECT!
Here's a before and after shot.
I don't know if those are the right settings for your camper.
AlanKilian is offline   Reply With Quote
Old 06-07-2023, 07:11 PM   #5
Hello again,
Cheers
Hey Jeremy. I'm about to order a new Flexiride and was just under my '73 1300 measuring. Was in very very tight quarters and with trailer intact but my numbers were 48" OB and 64" HF. So my question for you is if you did order this size and if so, did it fit well? I trust my measurements, particularly after reading that you had the same recommended to you. However, I saw a site (https://trilliumrv.wordpress.com/vin...um-repair-faq/) that lists both the original HF and the recommended HF for replacement axles as 65". Did you go with 65? Would like to hear your thoughts. Thanks!
Wandering Kev is offline   Reply With Quote
Old 07-03-2023, 01:53 PM   #6
Trailer: Trillium 1300 '78
BC
Canadian Axle in Inverary Ontario
We just took delivery of a FlexRide for our 1300 from Canadian Axle Inc in Inverary ON. The person who assisted us Michaela) was awesome to work with. It was ~$800 plus delivery, which was very reasonable to our remote island in BC and came to around $1100 all told. This all happened between May and June 2023. We're getting ready to stick it on as we speak. We opted for the electric brake option, just in case, but maybe that wasn't necessary for such a light trailer. Might be handy if we end up getting a smaller vehicle to tow it around.
Crash420 is offline   Reply With Quote
axle, trillium
Sourcing out stove parts fofobraselio Problem Solving | Owners Helping Owners 2 07-21-2018 04:09 PM
New axle on Trillium 1300 1976 x2uol Problem Solving | Owners Helping Owners 7 04-06-2013 06:12 AM
Please help. Sourcing out leaks after rainstorm CheekyTracy Problem Solving | Owners Helping Owners 49 08-03-2012 11:28 PM
Trillium 1300 Axle Check, Fitting Electric Brakes Richard Hayes General Chat 2 08-23-2009 10:54 PM
Trillium 1300 '78 Axle Seal Part Number Larry C Hanson Towing, Hitching, Axles and Running Gear 2 07-14-2009 12:47 PM
