while a full eight feet wide is sure nice when you're inside the trailer....towing a
Bigfoot with a narrower vehicle like an SUV does create a problem....like not being able to see behind you unless you are on a curve. I tried mirror extension and that was a waste of time. Somebody had given them to me and after trying them out I understood why.
I got this camera set-up from "EachBuyer"...it cost fifty something dollars...(USD) ships from Singapore in a week or two...never any duty or other fees. I've used them for a ton of stuff
the camera is designed to mount at the
license plate but I opted to mount inside...for now anyways (mounted inside, it won't work very well at night as the "night lights" will be reflected by the window...but I don't ususally travel at night and even if I did, rear vision is less of an issue where/how I travel)
Mounted this way the install is completely reversible with no permanent "damage"
camera and transmitter are powered through the rear sofa overhead
light...it uses .15A
screen and receiver powered via a cigarette plug into dash receptacle
Happy motoring !
