Thoughts on axle/frame replacement on ‘82 Burro - Fiberglass RV
Old 04-21-2022, 07:04 PM   #1
Trailer: Burro
Hi y’all. I’m a new owner to a 1982 13ft Burro (5days!) and I just discovered a few soft areas on the underside, which led me to inspecting further on the axle and frame. I have no idea what I’m looking for, but thought some of you seasoned owners could put some eyes on the axle and frame. Is this something I need replaced? Any concerns? I do see an area on the right front side of the wheel well where there is a rusted area… maybe 5 inches or so. Any feedback would be greatly appreciated! Thanks!
6D8CCEA1-A4FB-48EA-A043-75CF14E847F8.jpg   03501257-2CA8-4EAF-A795-E96A6551C0D2.jpg
925BCB11-3B66-4A2B-A5A5-EEEC28B9F71B.jpg   2D902DE6-4B14-4472-9E07-97BAECBC46EA.jpg
B9E8754C-8275-4B36-A717-E82FE218288B.jpg   783C50CF-95B4-4EAC-8E05-531EB90C8C22.jpg
1B3C1666-BC33-4B61-B1D0-FFEFFEBE1E80.jpg   02D6FEA3-F1F3-4ECA-949D-9C477B60BAA0.jpg
Theycallmesb is offline   Reply With Quote
Old 04-21-2022, 11:28 PM   #2
Mark in Vancouver's Avatar
Trailer: Triple E
I've recently spent quite a bit of time under my trailer. What I see in your pictures is some superficial surface rust. I see a couple of soft spots on the trailer where it looks like someone has filled some cracks with some compound or tried to seal some damage from water ingress. Not a big deal. Just get a sanding disk for your drill or grinder and get it clean, then repair with a little fiberglass and resin, sand it and and paint it. It's sometimes hard to tell when a frame is rusted internally. I have a small hammer that I tapped all over the frame. If the frame is almost rusted through, you can often hear a difference in pitch. If you do, take a screw driver and try and push it into the frame. You can sometimes find rot that way (my car in high school didn't like Canadian winters and salt and I could poke holes in my fame). I used a wire wheel on a grinder and went over the whole trailer frame a few weeks ago. I wasn't about to do a frame off restoration like some of the ambitious people do! No issues and it looked far worse than yours when I started. From what you've posted, I think yours is probably fine, although I don't know this particular trailer, but have had a few different ones over the years. Good luck and enjoy your new baby! You guys don't need brakes on those trailers I guess. I had to put them on mine. You might want to get some of that split plastic wire loom and put it over the wires and strap them to the frame where you can. Better than having them slap around in the wind and break or short....I did that when I re-wired mine.
Mark in Vancouver is offline   Reply With Quote
Old 04-22-2022, 12:14 AM   #3
FRED SMAILES's Avatar
Trailer: 13 ft Boler
I agree!
I think quite a few frames get trashed before their time.
Find someone with welding and fabrication experience to look at the frame. Dont expect it for free and ask them to explain any opinions.
Good luck with your decision.
Fred
I'd rather do it myself, done right or not. Isn't that what a hobby is all about?
https://www.fiberglassrv.com/forums/...ler-55601.html
FRED SMAILES is offline   Reply With Quote
Old 05-02-2022, 04:46 PM   #4
In your picture 5 and 6 the bottom edge of the fiberglass is crushed against the frame. Mine was like that too, but only on the passenger side, when I bought my trailer back in '09, but it hasn't changed at all the whole time I've owned it. Poke around the area both underneath and above to make sure your flooring is solid and to rule out a soft floor as the cause. I think when the trailer was built the part of the fiberglass that wraps around the floor was really thick and that got crushed until the floor met the frame, then it stopped.
ThomasE is offline   Reply With Quote
axle, burro
1983 Burro 13r axle replacement Alan C. Problem Solving | Owners Helping Owners 5 04-07-2016 03:14 PM
13' Perris Pacer Frame and axle work... to do rudock1 Problem Solving | Owners Helping Owners 24 02-06-2013 08:57 PM
Burro frame and axle question Mike Magee Towing, Hitching, Axles and Running Gear 5 08-06-2010 10:41 AM
New Frame/Axle Barbara Gardin Towing, Hitching, Axles and Running Gear 8 03-01-2009 06:32 AM
Axle and frame work Carol A. General Chat 10 05-20-2007 10:06 PM
