towing - Fiberglass RV
Old 02-26-2020, 12:41 AM   #1
Trailer: currently shopping
gulfport
towing
would i be ok to tow a 2007 casita 17' deluxe with my ford explorer with the factory tow package ? or do i need a wdh? my ford is rated at 5000 towing
rjl1226 is offline   Reply With Quote
Old 02-26-2020, 06:52 AM   #2
ShelbyM's Avatar
Trailer: Casita SD
See if your door sticker lists payload. That will be your limitation if there is one.
Old 02-26-2020, 07:12 AM   #3
towing
A 5000# tow rating is sufficient to tow a Casita 17D. Whether it will be satisfactory for you depends on your driving style, performance expectations, and the type of terrain you tow in. What year and engine do you have? Is it a FWD or RWD chassis (depends on year)?
As to weight distributing hitch use...
(1) What does your owner's manual say?
(2) What kind of hitch do you have- factory integrated or bolt-on, and is it rated for WDH?
The answers determine whether it is required or even possible. Not all vehicles and hitches are capable of handling the forces of a WDH.
As to whether it is beneficial, if the owner’s manual doesn’t give a specific threshold, the best way is to get axle weights of your vehicle before hitching up and again after hitching up the fully loaded trailer. Include a full tank of gas and all passengers and cargo that will be on board when you travel. A cruder method is to measure the ground-to-wheel arch height front and rear. If the rear axle is at or near its rating and/or if the front axle is being significantly unloaded, WDH is indicated.
With a tongue weight typically over 400#, I suspect you might benefit from WDH. In addition to redistributing weight evenly across both axles, WDH can reduce the porpoising motion you can sometimes get with a heavy tongue load on a softer rear suspension, making for a more pleasant ride.
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 54 01-02-2024 09:43 AM
Towing like you're not even towing? swoosh Towing, Hitching, Axles and Running Gear 18 07-30-2015 09:18 AM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
