Towing a Bigfoot 25 - Reccomendations - Page 5 - Fiberglass RV
Old 01-31-2022, 11:39 AM   #81
RKH
Trailer: bigfoot
Montana
I have a 1ton chevy and tow my 25 ft with our stabilizer hitch no problems whatsoever.
RKH is offline   Reply With Quote
Old 01-31-2022, 11:43 AM   #82
John in Santa Cruz's Avatar
Mid Left Coast
Originally Posted by John in Santa Cruz View Post
oh yeah...
I have to admit, I'm kinda a fan of older stuff. new vehicles have too much computer crap on them for me. I don't trust driver assist stuff, and I think its making people worse drivers. my daily driver is a 1993 Mercedes 300CE Cabriolet (convertible).
I like stuff that lasts. this song says it for me...
huh, my previous yooutube section went away, k, try here..
meanwhile, said daily driver has been retired, and replaced with a 2016 Mercedes E350 4Matic wagon which has all that 'computer crap' in it, including Android Auto so I can use my google maps and spotify, and headlights that autodim, and follow around corners, and lane warning and I'm getting kinda spoiled.
Old 05-09-2022, 04:23 PM   #83
Towing a 25 foot Bigfoot Camper
Originally Posted by Bruce H View Post
Get a 3/4 ton or one ton single rear wheel truck with a towing package that includes built in brake controller and large extendable mirrors that include large convex mirrors. I tow mine with an F-350 Ford with the gasoline engine. My fuel mileage is within 3mpg of a 1/2 ton and it is well worth it. Plenty of power, much more stable and safer plus I was able to throw away my much hated "equalizer bars". I have tried several different 1/2 tons and I like this much better.
Bruce - you are towing just off the bumper then (no WDH)? I'm curious because I just purchased a Ram 2500 Mega Cab (160" wheelbase) and have a 25' Bigfoot on order and am debating whether I really need a WDH. I realize everyone will say WDH is safer, etc., but interested in real life experience of anyone towing one with a 3/4 or 1 ton truck without a WDH.
Camper Chuck is offline   Reply With Quote
Old 05-09-2022, 04:29 PM   #84
Originally Posted by Nvboatman View Post
We tow our Bigfoot 25RQ with a 2018 Tundra with tow package 5.7l engine. We live in the West and just returned from a long trip to Idaho and Montana. Averaged 11-12 mpg. I have an Anderson WDH/anti sway. I pulled the trailer quite a lot before we got the WDH, and never once experienced sway, even in brutal sidewinds.
As far as power goes, the Tundra has plenty to get you up and over the mountains.
I also installed airbags on the truck to level everything out when loaded. We are pleased with our setup 👍
Curious if you had towed a lot without the WDH with no problems even in strong cross winds, why did you then opt to add the Andersen WDH?
Old 05-09-2022, 09:28 PM   #85
Bruce H's Avatar
Trailer: Bigfoot 21 ft Front Bedroom
I don't need one and will not use one when towing with a 3/4 or one ton. My 25RQ had good balance and always trailed good.
Old 05-10-2022, 08:26 PM   #86
Mid Left Coast
what WDH's mostly do is reduce porpoising when you go over a bump or dip, it makes the ride up front more comfortable on a road full of dips and bumps.
Old 05-10-2022, 10:26 PM   #87
CharlesinGA's Avatar
I have a 25B21RB Bigfoot. Due to the location of the water tank at the very rear, the trailer is rather squirrely even with everything else as far forward as I can get it. That was until I added the Blue Ox Sway Pro hitch. It makes the towing very nice, you almost cannot even tell the trailer is back there. As John noted it eliminates the porpoising or chucking on uneven roads, crossing RR lines, etc
Mine is an extended tongue with the cargo pod, and I am not heavy but I have about 800 lbs on the tongue (measured with a Sherline scale and calculated from scale weights). I don't like having all that water weight in the rear, but many places I go do not have water and I have always traveled with a full tank.
I have a factory class IV receiver hitch and reading the owners manual carefully I found that the hitch, without Weight Distribution, is limited to 500 lbs tongue weight, which adds to the reasons for using the WDH.
The Blue Ox was minimally invasive as far as cutting fiberglass on the parrots beak and the brackets installed far enough forward so as to not interfere with the LP bottles (just barely).
Planning on a 350 or so mile trip in a week and I'll be interested to see how well it tows as I have replaced the nearly new but not enough KYB shock with Rancho XL9000 shocks (adjustable, currently set on 5 out of 9) and I replaced the upper A arms due to the boots being gone off the ball joints, and had it aligned which improved the tracking and feel by a good bit.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 10-16-2022, 08:31 AM   #88
Trailer: Bigfoot 25 RQ
Ohio
For our upcoming 25rq we just bought a ram 2500 gasser, payload is 3200 lbs, no plenty of capacity. It was a 2022 low optioned Bighorn. It wasn’t any more expensive than an f150 with medium options.
oldwave is offline   Reply With Quote
Old 10-16-2022, 11:10 AM   #89
Good choice. Dodges are cheaper than Ford’s and a 3/4 ton eliminates the need for wdh It is plenty of truck for a 25RQ. That being said, I still like my F150.
damueller is offline   Reply With Quote
Old 10-16-2022, 01:19 PM   #90
Mid Left Coast
yeah, just about everyone I've seen towing a Bigfoot 25 for any length of time has a 2500 class truck, be it chevy, ford, or dodge. mostly diesels., and mostly 4x4, so you can get out of a stuck spot easier.
Old 10-16-2022, 03:16 PM   #91
Ohio
Decided against the diesel with the cost of maintenance and the fuel and the 9,000 premium. Also while some 3/4 ton users tow without a wd hitch, we went overkill and are getting a ProPride hitch. Should tow like a dream.
Old 10-16-2022, 03:23 PM   #92
Ohio
Originally Posted by damueller View Post
Good choice. Dodges are cheaper than Fordís and a 3/4 ton eliminates the need for wdh It is plenty of truck for a 25RQ. That being said, I still like my F150.
I have a 2004 f 150 4x2 that has been maintained. Still a great truck and with 3t5000 oil changes no issues at all with the timing phasers. To get a proper f150 that would tow the bigfoot with what I consider to be sufficient payload, 4x2 5.0 liter or3.5 eco with max towing and heavy duty payload. My dealer had one on the lot, it was the same price as the Ram. F250ís were like hens teeth at this moment. They did have a nice xlt but wanted 6000 over the low 60ís price. I passed.
We will use the Ram exclusively for the Bigfoot, as daily drivers we have file efficient small cars.
Curious what flavor of f150 are you towing the bigfoot with ?
Old 10-16-2022, 06:51 PM   #93
2015 F150, lariat, supercab, 6.5’bed, 4wd with awd on lariat option (real nice in lots of situations), 3.5 EB, max towing, 1800 #payload, 11,000 #s towing, 86,000 miles currently, no mechanical issues.
Handled the 25RQ very well, If I was to go superduty I would get F250 with 7.3 gas. No need for diesel in my opinion.
Old 10-16-2022, 07:16 PM   #94
Ohio
2015 F150, lariat, supercab, 6.5íbed, 4wd with awd on lariat option (real nice in lots of situations), 3.5 EB, max towing, 1800 #payload, 11,000 #s towing, 86,000 miles currently, no mechanical issues.
Thanks.
bigfoot
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 54 01-02-2024 09:43 AM
Shop reccomendations in Reno,NV for door/axle replacement solarscamp13 Modifications, Alterations and Updates 6 03-26-2014 07:31 AM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
Electrical Reccomendations Brandegor Electrical | Charging, Systems, Solar and Generators 25 09-17-2013 11:28 AM
Battery charger reccomendations? DrewSK Care and Feeding of Molded Fiberglass Trailers 6 10-20-2012 08:39 PM
