05-23-2021, 09:52 AM
#21
Trailer: 2015 19 Scamp DLX
Towing a Scamp 19 my experience Part 2
Just about finished
I made a bracket system so I can replace the old hitch, change or modify the present hitch or build something new...
Proof will be in the "Pudding" I guess.
05-23-2021, 10:00 AM
#22
Scamp 19 Hitch
05-23-2021, 10:03 AM
#23
Scamp 19 Hitch
Just about done...
05-23-2021, 10:53 AM
#24
Scamp 19 Hitch
Last Piece, 12" setback adjustable height hitch, 2-5/16" Ball hitch rated at 8500#
05-26-2021, 10:52 AM
#25
Trailer: Trillium 1973
I use an iPhone or my camera and don't have to worry about orientation. Try looking for a setting in your tablet that turns off automatic orientation. I use Adobe Photoshop Elements for processing, but I think that's more than you want or need ( to spend ).
Photoshop has a free ap for phones etc photoshop express that might work for this
05-26-2021, 11:54 AM
#26
Can do
Its been a pleasure reading about your exploits my friend. You are not the type of person that frets and worries about changing a light bulb.
I hope you trip is a success. I know if you have any issues along the way you will stop in a greasy quonset hut out in the country somewhere and find a fella who welds plow blades all day and set 'ur to rights.
05-27-2021, 08:25 AM
#27
Trailer: Scamp 5th wheel
Great thread for pointing up the importance of matching tow vehicle to trailer.
Hope I am not behind you on the highway!
05-27-2021, 08:39 AM
#28
Trailer: Bigfoot 21ft (25B21RB)
Keep the progress pics coming.. I like your style...I used to build race cars so I am familiar with fabrication
Phil & Denise Underwood
1973 13ft Lovebug
1998 17ftCasita FD
05-27-2021, 09:14 AM
#29
Trailer: 13 ft Boler
With the truck you have, I think I'd a just made that Scamp into a trailer
with a bumper hitch. Would've kept the box empty and addstorage to the "5th". I dont like the Scamp 5th idea either.
Fred
05-27-2021, 03:20 PM
#30
By extending the support point so far forward of its initial location, your hitch is now transferring quite a large bending moment to its attachment point on the trailer frame, which wasn't the case with the original factory configuration. Hopefully the Scamp frame will be able to resist that additional bending moment.
05-27-2021, 04:56 PM
#31
Trailer: 17' Casita
Louisiana
Originally Posted by Seacap10
Just about done...
Not quite, Cap! We do a lot of steel fabrication down here in the 'oil patch'. And 'steelwise' we are a lot more generous than you are. Since your are very good at welding; I would add 1/4" thick 'brackets' shown in red (yours are on the 'skinny' side). This would beef up the X axis section modulus and should take care of vertical forces. I am still worried about the Y axis section modulus and horizontal bending moments. Go easy backing up or stepping on the brakes.
05-28-2021, 10:07 AM
#32
Trailer: Scamp 1995 19'
LOL. Amen to that!
05-30-2021, 08:32 AM
#33
Those Gussets are already in... I didn't want to deal with any "Notch effect stresses"
Those are 3/8" gussets on 3.5" x 3.5" 1/4" wall HSS steel.
I'm no "engineer" but this trailer only weighs 3000# odd pounds.
I appreciate Icebreakers comments regarding the scamps frame is likely now the "weak link" and will be reinforcing the factories 2 x 3" transverse tubes that support the 12 x 12" mounting plate...
Remember the original mount is only 3.5 x 3.5" with 2 gussets at an odd angle welded to an off the shelf hitch.
You will be allot safer behind me on the highway than a Factory hitch.
If something goes seriously wrong with this rig, I will be towing a queen size FRP bed with no wheels and watching a scamp 16 sailing off into the weeds in my rear view mirror LOL.
I am pretty sure no "Engineer" came up with the Scamps coupler rig?
Sorry for sounding defensive LOL. This is all meant to be an "informational discussion" ?
05-30-2021, 11:19 AM
#34
Close up Picture of "Universal" base mount
You can swap out coupler type similar to a Reese Goose Box type system.
Snug fit 3.5 x 3.5 with 3 x Grade 8 bolts
(Zero play had to use a 5# hammer to slide it in...)
05-30-2021, 05:07 PM
#35
Trailer: 17' Casita
Louisiana
We appreciate your posting of this design & fabrication. I wish I could weld as well as you do.
We just compared with our steel fabrication practices here on the Gulf of Mexico. What you are doing may be perfectly all right in your neck of the wood. Do you have to go through a trailer inspection in BC ?
06-02-2021, 09:59 AM
#36
Trailer inspection ?
I have built a few trailers over the years here. Inspection here is pretty straight forward. There is an inspection process but it basically ensuring the coupler, axle and lighting are correct. Nobody looks at the design engineering or does welding inspections.
If I were approached by a commercial transport (Highways Inspector) he would see my approval stickers and wouldn't have anything to discuss...
To Cover my Axx I also had a certified welder / fabricator inspect my welding and he signed off on my build.
We are not quite as litigious in Canada as the USA so do your research.
07-05-2021, 09:09 AM
#37
Success It Tows like a dream
The Gooseneck works great follows like a Goose headed North...
No wobble no wiggle What a pleasure to "Jack Knife" into a tight parking spot.
Lots of clearance vertically and at box corners...
07-05-2021, 09:58 AM
#38
The adjustable height hitch
Height adjustable Gooseneck hitch / coupler
07-05-2021, 11:02 AM
#39
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
It might not make any difference to you in your application, but your safety chains are illegal in the Commonwealth of Massachusetts according to 540 CMR 22.10
"... two safety chains shall connect the trailer and the towing vehicle, one on each side of the central trailer hitch..."
Reference: https://www.mass.gov/files/documents...9/540cmr22.pdf
I took my trailer to a local welding place and had them update my chains so one was on each side of the trailer hitch.
Scamp had one chain with two hooks bolted to the hitch in the center which REALLY didn't seem safe to me.
07-05-2021, 11:39 AM
#40
Darned cool improvement on the idea.
