It looks like you found a good thread with people discussing this. My two cents is that I would get a universal rail kit installed and then you would be able to use a gooseneck fitting or a fifth wheel.
I like bolt on, but wouldn’t be adverse to a welded on universal kit if you trust the welders. My welder doesn’t
paint, so I’d have to do all the
painting after he welded it. Maybe yours is more full service.
Try to get the rails centered over the
axle, may a bit to the rear. The problem you have is that the pin box on your trailer will hit the tailgate if you go too far back, but the trailer will hit the cab in turns if you are too far forward. I’m not familiar enough with your trailer to know which is more likely in your setup.
Park your truck under the tongue and swing a tape measure about for a good bit. Have a friend check your thinking.
