Towing with an electric vehicle - Fiberglass RV
Old 07-18-2022, 07:51 AM   #1
Indiana
We now have a little real-world experience towing our 1978 Trillium 4500 with our 2022 Tesla Model Y Long Range. I'm happy to share our experiences, but also look forward to learning from others who tow fiberglass rvs with an electric vehicle.
We successfully completed a five day tour through Northern Indiana and Southeast Michigan yesterday. We camped one night at Potato Creek State Park and three nights at Tri-Ponds Campground near Allegan Michigan. We charged at both sites, utilizing a TT-30 adapter.
Two of the travel days were around 90 miles, which was no sweat with our rig. The last leg home was 150 miles, which I think may be near our limit without stopping to charge. Please understand that this is fairly flat Indiana and Michigan with optimal weather.
We did stop to charge once, but that was only because I had left my wallet at home and decided to make the 180 mile round trip home on morning number two. Another lesson learned.
Without that screw-up, we could have completed the trip (and side-trips) without using a Supercharger. I'm glad we needed the Supercharger stop as this was our first experience, and it was great.
As I said, both sites were 30 amp sites. This was adequate for our needs this time, but I'm going to try for 50 amp campsites when possible.
It was a real surprise how accurate the Tesla navigation predicted the energy required to each destination while towing. The navigation shows what percentage of battery will be left at the destination, and after towing a few miles, it was accurate to within a few percent. If the prediction is too low, the program adds a stop at a Supercharger along the route.
The only problem we experienced was on the first day the Tesla Charging Connector detected excessive heat at the plug into the TT-30 outlet. It automatically cut the current pull in half (12 amps) and sent a warning to check the connection to my phone. I disconnected, checked for corrosion in the plug, let it cool and reconnected (it resumed 24 amp charging). This recurred a few hours later, so I wonder if putting a little dielectric grease on the plug contacts might have prevented this.
Prior to the Tesla, we have towed with a 2015 Honda Odyssey. Both have a 3500 pound towing capacity, but the Tesla seems more stable and is all-wheel drive.
The Odyssey has the advantage of a large cargo area, so we may continue to tow with it when we take our bicycles. We're also unsure which vehicle to use when we plan longer adventures, especially out west where the charging infrastructure seems less developed at this time.
Steve Hague is offline   Reply With Quote
Old 07-18-2022, 08:46 AM   #2
ShelbyM's Avatar
Trailer: Casita SD
Informative, thanks!
Old 07-18-2022, 12:22 PM   #3
Heres an informative video on this subject and the conclusion of the guys that made the video.
Lee
Captleemo is offline   Reply With Quote
Old 07-18-2022, 01:35 PM   #4
ShelbyM's Avatar
Trailer: Casita SD
Yawn. Been there.... https://www.fiberglassrv.com/forums/...son-99024.html
Old 07-18-2022, 01:39 PM   #5
Radar1's Avatar
Trailer: 2020 Escape 19 (was 2005 16 ft Scamp Side Dinette and 2005 Fleetwood (Coleman) Taos pop-up)
Thanks for the information. It seems right now the electric vehicles used for towing are best served by towing our smaller and lighter campers.
Sharpsburg, GA
radar1-scamping.blogspot.com
Old 07-19-2022, 08:06 AM   #6
Trailer: T@B
Great write up Steve. Thanks for the info. Glad to see another person towing with a model Y.
The navigation prediction for us was a little less accurate as we were towing in more extreme conditions. Wind, mountains etc. But I’m sure that will get better in time.
It will be nice to be able to compare notes with someone other than on Facebook.
Thanks again Steve.
Here’s a pic of our Tesla T@B 400 combo.
Travellers is offline   Reply With Quote
Old 07-19-2022, 05:12 PM   #7
Indiana
John,
I really like the look of your rig, I'm sure it turns a lot of heads going down the road. Looks to be quite aerodynamic. I look forward to hearing more of your experiences. Since you are pulling with a Tesla Model Y, you will appreciate this data.
Our first leg was pretty much cross country, county roads and some state and federal highway with 55 MPH speed limits. Distance was 93 miles and we used 425 Wh/mile.
I forgot to record our second leg.
The last leg (to home) was primarily interstate. I probably averaged 65 MPH, but that is just an estimate. We covered 150 miles with an average energy use of 465 Wh/mile.
I know this was pretty near optimal conditions and look forward to sharing data from less optimal conditions as the seasons change and we venture away from the flatlands.
Steve
Old 07-19-2022, 05:34 PM   #8
Trailer: T@B
Originally Posted by Steve Hague View Post
John,
Steve
Those are great numbers. The smaller profile works well for you. It will be fun to compare numbers because my numbers are in watt hours per kilometre and yours are in watt hours per mile. .
Our most efficient run was 320 watt hours per kilometre…and I’ll let you do the conversion. But I think it’s around 540 watt hours per mile. I’ll see if I can put a screen shot up later.
Old 07-19-2022, 05:48 PM   #9
Trailer: T@B
Found it. Remember, this is watt hours per kilometre. 90 kilometres per hour. (56 mph) it shows 124 kilometres of range left at 50 percent on the battery. Sounds about right. But I can also say it was common to see 360 watt hours per mile as well. Depends on conditions I guess.
Old 07-23-2022, 10:09 AM   #10
DeanCHS1980's Avatar
Kentucky
Hi Steve,
Congratulations on getting the Tesla. Thanks for the camping/towing update.
Hope to see you guys again in the campground sometime soon!
Take care,
Dean
Laura & Dean | '05 Casita 17' FD | ‘24 Chevrolet Colorado Z71 in Glacier Blue Metallic & RSI SmartCap EVOa | '09 Kia Borrego Limited V8 2WD (December, ‘15 to August, ‘24 - 164,000 miles (purchased with 83,000 miles), visited 15 states, towed 35,000 miles, 13 mpg towing plus/minus 1 mpg).
DeanCHS1980 is offline   Reply With Quote
Old 07-23-2022, 10:26 AM   #11
Trailer: 16 ft Casita
I will never own electric vehicles first off truck big enough to pull my trailer cost 80,000 dollars and range of 150 miles and most campgrounds will not allow you to charge them .
johnlochbuie is offline   Reply With Quote
Old 07-23-2022, 10:33 AM   #12
Trailer: T@B
Yah to each their own John. Everybody has different wants and needs for transportation and tow vehicles.
But re charging. Our experience has been the opposite of yours. So far we have never been told no when we ask about charging. The only common request is that only one thing gets plugged in at a time. And one had a 10 dollar surcharge and you had to rent a 50 amp site. We don’t need a 50 amp site so we declined.
Some campgrounds are already putting it out there on the various apps that they support electric vehicle charging so I’m sure it will catch on as it draws business.
Cheers and safe travels.
Old 07-23-2022, 12:30 PM   #13
ShelbyM's Avatar
Trailer: Casita SD
I will never own electric vehicles....
That's OK. They sell all they can build to folks who want them.
Old 07-23-2022, 01:55 PM   #14
Alabama
I think that’s pretty neat if you plan your trip well have lots of time and charge at campgrounds you travel for free.
StevenMaria is offline   Reply With Quote
Old 07-23-2022, 02:36 PM   #15
Hardly free, considering the high price of admission to ownership of a tow-ready EV. "Free" charging with the price of a campsite is likely a short-lived benefit for early adopters.
Old 07-23-2022, 03:45 PM   #16
Trailer: T@B
Depends. Probably the most common EV towing vehicle right now is a Tesla model Y with a tow package. So 60 thousand bucks USD plus tax. Pretty much everyone towing with a model Y though is towing a teardrop trailer of some kind. Good combo for us.
I don’t think I would plan charging around campsites, but when we are touring we often travel no more than 50 to 150 kilometres every day. Those days I suppose one could do most charging at a 30 amp campsite. Lots of times we are dry camping in provincial parks though so a lot of our charging is done at superchargers or DC fast chargers. Still relatively cheap though.
We have towed about 12000 kilometres this year so far. I would say about a third is freebie charging. Family members driveways. Touristy, L2 chargers and campgrounds. But the other 2/3 would be superchargers etc.
Lots of half ton electric pickups hitting the road right now. They will be the dominant ev towing vehicles soon.
Jmho. Not an expert.
Old 07-23-2022, 04:45 PM   #17
John in Santa Cruz's Avatar
Trailer: Escape 21, behind an '19 Ferd Expedition
Mid Left Coast
Originally Posted by Travellers View Post
... Lots of times we are dry camping in provincial parks though so a lot of our charging is done at superchargers or DC fast chargers. ....
I haven't seen a supercharger yet that would support driving through with a trailer. and most, if you tried to pull in with a trailer behind you, you would be blocking the whole parking lot behind you.
Old 07-23-2022, 06:16 PM   #18
Trailer: T@B
Hi John. Yah we haven't been to a single pull thru Supercharger on our travels in Canada although I see pictures of them in the US quite often. We just don't rate up here
Anyway, I would say about a third of the superchargers we have used have had trailer stalls. They work for short trailers like ours but if the cybertruck ever hits the road the trailers are going to get bigger.
Ill put up a few pics of our rig in various superchargers across Canada. I would say we have had to disconnect less than 6 or 7 times...maybe 8. Our rule was that if there was a chance we would inconvenience somebody by blocking stalls we just unhooked. So here are a few pics, mostly superchargers and a few public chargers, all level 3. Keep in mind we are retired so we mostly travel when everyone is at work, so quite often superchargers were quiet. Here we go...in no particular geographical order.
I believe this was in southeastern ontario. Most of these were pretty good although a few of them caused our tail to stick out a bit. We had traffic cones for those situations. These are usually in mall or strip mall parking lots.
I believe this was in Canmore Alberta. We saw 4 or 5 like this with back access. It worked...but wouldn't want a longer trailer.
This is in Sault St Marie on the Canada side. Cool shot. Just a little Supercharger. We made it work.
This one is Coburg Ontario...I think... Less chance of a problem when they are this size...as long as its not a long weekend.
This one is in southern BC...somewhere.... Maybe Castelgar. This is a FLO station. Kinda slow at 50 KW but actually a slow charger is kinda handy at lunch as you don't have to scarf down your meal to beat the charge complete text.
This one is Drummondville Quebec. We used it twice, once on the way in and once on the way back. Worked out good but this was actually a fairly busy little supercharger. Thought for sure I was going to have to move at one point.
And speaking of Quebec city. Go. Its amazing.
And one non DC fast charger location. This is Waterton Lakes national park. The Canadian side. We were here for four or five days and sucked up 10 or 15 kwh per day while touring around the area. We used our own EVSE and TT30 adapter in campgrounds except for one campground that had a level 2 destination charger. This was a 30 amp site although I figured out on the last day the opposite side of the post had a 50 amp plug. We only paid for a 30 amp site so that's what we used.
And one more vanity shot. See the other end of that lake? That is the United States of America Very cool national park. Lots of hiking. I think we coughed up a lung getting to this viewpoint. Highly worth it....I guess
Hope that helps John.
Cheer and happy travels.
Old 08-01-2022, 06:37 AM   #19
Indiana
Second EV camping trip
Still newbies at this, but we towed our Trillium 4500 to the Northern Indiana Vintage Trailer Rally last week. We camped on a 30 amp site again. I called ahead to make certain that it was OK to charge our Tesla Model Y Long Range at the campsite and they replied that we could. They even looked up our reservation to make certain that it was a 30 amp site.
We left home charged at 100%, drove 76 miles mostly on 2-lane highways at 55-65 mph, and arrived at the campsite with 57% battery capacity remaining (427 Wh/mile).
We were the only fiberglass trailer in attendance, so we were a bit of a curiosity, though I was surprised that several were familiar with Trilliums and fiberglass rvs in general. There were two 1970's fiberglass motor homes (FMC for one). Must have been huge molds they came out of. Of course, we were asked many questions about EV towing as many of the small vintage stickies were of similar size and weight. I shared what little I know at this time and had several interesting and hopeful discussions on the future of rv travel.
On the first day of charging at the TT-30 post I again experienced a reduction from 24 amp to 12 amp charging. I stopped charging and applied dielectric grease to the plug and recepticle and was able to charge at 24 amp. I'm not sure whether the dielectric grease did the trick, but it didn't hurt.
I intentionally only charged to 90% on the morning we departed. We took a different, but similar route home, travelling 85 miles using 443 Wh/mile and arrived home with 38% charge remaining.
We have some longer trips planned this fall that will require charging along the way. Those should be more interesting. I appreciate hearing from the more experienced and adventurous.
Steve
Old 08-01-2022, 07:18 AM   #20
ShelbyM's Avatar
Trailer: Casita SD
Thanks
Latest Electric Tow Vehicle honda03842 Towing, Hitching, Axles and Running Gear 18 08-07-2015 04:19 PM
Propane & Electric vs Just Electric Wallo Care and Feeding of Molded Fiberglass Trailers 75 03-06-2014 06:24 PM
All Electric Tow Vehicle? Art Davis General Chat 3 04-16-2008 02:27 PM
All electric, or gas and electric? Homer Teitsma Electrical | Charging, Systems, Solar and Generators 24 10-07-2007 11:10 AM
