Towing with Honda Pilot - Fiberglass RV
Old 03-13-2021, 08:37 AM   #1
Trailer: 2015 Escape
If you’ve towed with either a Honda Pilot or Ridgeline did you need airbags or a weight distributing hitch? I have a 2019 Pilot that I have not yet towed with. I have a 2015 Escape19. Thanks
rgrugg is offline   Reply With Quote
Old 03-13-2021, 10:15 AM   #2
Trailer: currently shopping
Honda towing
Would be good to check with Honda on the WDH, as they in the past have advised against using one - guess there can be issues.
DaveMinBako is offline   Reply With Quote
Old 03-13-2021, 10:25 AM   #3
Trailer: Casita 2004 Spirit Deluxe
I have towed my Casita 17" with a 2013 Pilot for 18 months and have had no problems. Mine is rated for 5000 lb.
Don Barnes is offline   Reply With Quote
Old 03-13-2021, 10:44 AM   #4
Trailer: Bigfoot
I tow a lighter trailer, a 17' Bigfoot with my 2010 Gen1 Ridgeline and I use a WD hitch...really works well.
threepine is offline   Reply With Quote
Old 03-13-2021, 10:54 AM   #5
Jon in AZ's Avatar
Their warning is a bit ambiguous, along the lines of "not recommended because an improperly adjusted WDH can cause..." Sounds more like lawyerly CYA from damage due to improper use than a blanket prohibition. With a FWD or AWD vehicle towing near the maximum recommended tongue weight, a properly sized and tensioned WDH will improve handling and ride. With an independent rear suspension it might also prevent uneven tire wear due to rear end squat. It should not be used to exceed the rating, of course.
What's the typical tongue weight on your E19, Bob? Will you carry much in the way of extra passengers or gear in the back?
Old 03-13-2021, 12:18 PM   #6
Originally Posted by Jon in AZ View Post
Their warning is a bit ambiguous, along the lines of "not recommended because an improperly adjusted WDH can cause..." Seems more like a legal protection from damage due to improper use than a blanket prohibition. With a FWD or AWD vehicle towing near the maximum recommended tongue weight, a properly sized and tensioned WDH will improve handling and ride. With an independent rear suspension it might also prevent uneven tire wear due to rear end squat. It should not be used to exceed the rating, of course.
One extra passenger and gear in the tow vehicle will likely be less than 100 pounds.
Old 03-13-2021, 12:34 PM   #7
Trailer: Scamp 16ft
Wisconsin
2016 Honda Pilot
I towed our Scamp 16 (rated 5000 lb) without a WDH and never had a problem. Looking forward to doing the same with our 2021 Pilot.
RussRich is offline   Reply With Quote
2017 Honda Pilot towing capability corgicat Hi, I am.... 11 03-18-2017 07:19 AM
06 Honda Pilot 2WD Towing 16' Scamo DLX Ray R Towing, Hitching, Axles and Running Gear 5 05-22-2016 02:37 PM
Honda Pilot towing capacity Bludfang General Chat 27 11-21-2015 04:21 PM
2016 Honda Pilot Towing Specs Jon in AZ Towing, Hitching, Axles and Running Gear 0 05-20-2015 12:16 PM
Honda Pilot Towing honda03842 Towing, Hitching, Axles and Running Gear 86 09-11-2014 09:05 PM
