Trailer Brake Magnet Retaining Clips - Fiberglass RV
Old 07-10-2023, 07:24 AM   #1
Trailer: 2017 Scamp 13D & 2016 Highlander
Iowa
I have a 2017 Scamp 13' and while cleaning and greasing the wheel bearings I noticed the right side brake magnet clip was missing and the electric wires were broken at the magnet. I ordered new magnets and while installing the retaining clip it broke. These are 7" brakes.
Questions:
- Does anyone have a good source for these little clips?
- What is the best way to install them without damaging them?
- Can I use the clips from 10" or 12" brakes? These look like a better design.
GpaNed is offline   Reply With Quote
Old 07-10-2023, 08:27 AM   #2
Raz
Raz's Avatar
I usually find them missing. The 7" are flat and tend to be hard to find. The 10" are triangular shaped. Both have a tab that engages a slot in the magnet control arm. Etrailer claims you can use either. There's also a spring that rusts. I think that comes in the magnet kit. While etrailer sells the clips, postage will be high. As this is a common problem, I'd try a local RV store. I've read Napa sells the 10" clips though I've never looked. I use a needle file to clean the slot. Good luck.
Old 07-10-2023, 08:48 AM   #3
Iowa
Raz, Thanks for the advice. I checked Napa and they have a pack of 5. I will get them and replace both sides.
Installing a front dinette while retaining bunks, couch and porta-potti in 13' Scamp" Scamper Jim Modifications, Alterations and Updates 100 09-14-2020 02:48 PM
Pre '88 Trillium Axle Brake Magnet Ian Pearce Problem Solving | Owners Helping Owners 0 08-04-2014 06:34 AM
2.5 inch retaining ring ... how to remove ... freddo411 Problem Solving | Owners Helping Owners 12 05-08-2012 07:01 AM
Brake magnet thunter Towing, Hitching, Axles and Running Gear 6 04-27-2012 05:06 PM
Tekonsha 10" magnet kit in CANADA?? Francis McDermott Care and Feeding of Molded Fiberglass Trailers 6 03-23-2009 03:58 PM
