trailer brake setting in tow vehicle - Fiberglass RV
Journey with Confidence RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 11-09-2021, 08:18 PM   #1
Governor Bud's Avatar
Trailer: 2005 Bigfoot 21
Free State of New Hampshire
Bigfoot 21 owners and others….
in my ram 1500 trailer control there is a choice in the trailer brake type functions between light or heavy electric, light or heavy Electric over hydraulic.
What selection have you made? I have the 2005 bigfoot 21. Thanx for any education.
Governor Bud is offline   Reply With Quote
Old 11-10-2021, 06:43 AM   #2
IMEd's Avatar
Trailer: Bigfoot 25 RT
My Ford wants low/ light , electric.
Your trailer does not have hydraulic brakes.
IMEd is offline   Reply With Quote
Old 11-10-2021, 09:26 AM   #3
Trailer setup for RAM
In researching further, the selection for the RAM/Bigfoot combo appears to be light electric.
When would one use the other modes?
Old 11-10-2021, 04:56 PM   #4
IMEd's Avatar
This is from Ford but, I suspect, the principle is similar for other brands,
Trailer Brake Effort Setting
The trailer brake controller allows the user to customize how aggressively the trailer brakes engage. The default value is "Low" and is the recommended setting for most trailers. If your trailer's brakes require more initial voltage, or if you prefer more aggressive trailer braking, then select either the "Medium" or the "High" setting
Old 11-11-2021, 06:44 AM   #5
Massachusetts
Originally Posted by Governor Bud View Post
"...there is a choice in the trailer brake type functions between light or heavy electric, light or heavy Electric over hydraulic.
Thanx for any education."
Jon MB here, not Bonnie. Don't blame her for my postings....
The selection is narrowed by the brake type: All electric (electric solenoid to press the friction material against the hub or disk), or combination electric/hydraulic (electric pump to pressurize brake fluid that then presses the friction material).
The correct selection is dictated by the brake type installed on the trailer.
The 'light' or 'heavy' selection is operator preference.
Bonnie RB is offline   Reply With Quote
bigfoot
Optimum voltage setting for brake controller Thinh Towing, Hitching, Axles and Running Gear 13 07-08-2013 04:57 PM
Setting Your Trailer Brakes ronsmith100 Towing, Hitching, Axles and Running Gear 3 04-21-2009 03:05 PM
Prodigy brake controller setting? Christi V. General Chat 15 02-16-2008 01:21 PM
Setting for Fridge Alan P. Problem Solving | Owners Helping Owners 5 08-13-2007 04:19 AM
Setting tension on sway control Chris Z Problem Solving | Owners Helping Owners 3 04-13-2006 10:29 PM
