Trillium 13' - Brakes and Bearings - Fiberglass RV
Old 12-28-2016, 08:11 AM   #1
Trailer: '77 Trillium 1300
Hey, all! Wasn't sure if there was a resource here for this type of thing... I'd like to put electric brakes on my '77 Trillium 13' but I'm not sure what size would work. Also, I need to replace the bearings and don't know that size either... are these items I'd need to measure somehow or is there "a standard size" for all these eggs?
Thanks for the assist!
'77 Trillium 1300, pulled with VW Jetta Sportwagen TDI
Hitch is an Ecohitch
respond2us is offline   Reply With Quote
Old 12-28-2016, 09:59 AM   #2
ckayaker's Avatar
Trailer: Trillium 4500
I suspect the bearing sizes are stamped on the outer ring of the bearing so you could get that when changing them or when greasing them. Of course that would mean waiting for the new set...
I suspect others will know the sizes...
ckayaker is offline   Reply With Quote
Old 12-28-2016, 10:01 AM   #3
Yep, thanks for the word. Good idea, though. I could just pull a wheel off, get the size, and put the wheel back on until I get the bearings in. Thanks a bunch!
Old 12-28-2016, 10:06 AM   #4
Electric brakes can be added. If you have an axle with brake mounting flanges you can add brakes to your current axle. If you do not have flanges on your axle you would have to also replace the axle.
Old 12-28-2016, 10:13 AM   #5
Thank you for the input, sir. I'll check that also. Is the size of the brakes the same on all these, or does it vary by model?
Old 12-28-2016, 12:39 PM   #6
I plan to put electric brakes on our '76 Trillium and had the RV place look at it last year. Ours and I suspect yours has the right axle mounts for adding brakes. A couple of points to consider:
a. Check your torsion axle by jacking up each side in turn and making sure it is extending and compressing properly before spending money on brakes. Changing the whole axle is also an option. My axle turns out fine but these are old machines.
b. My RV guy in any case first recommended changing the whole axle for a new one with brakes already installed as there isn't a huge difference in price. The axle on our '76 however is welded to the frame which would make it quite a lot more difficult to change. I don't know how your '77 might be mounted.
If you have a reliable RV maintenance place, they should be able to advise you on bearings/brakes/axles, and probably will order them for you, even if you decide to do the work yourself.
Randy J. is offline   Reply With Quote
Old 12-28-2016, 12:57 PM   #7
Randy, wow... you went over and above, buddy. Thanks for the info. I had no idea about the axle replacement option (with brakes already attached). Very cool. I'll check into that and see what makes more sense. I really appreciate you.
Old 12-28-2016, 01:54 PM   #8
bullfrogeh's Avatar
Axle/brake/and bearing renewal ?
We had the same dilemma as you, but with our 1973 Boler. I had the expert, (Paul Nuemeister of Sebringville, for those of us in Ontario and several northern states) examine the 43 year old axle. He then ordered the new axle and associated brakes. I returned a couple of days later for the installation, knowing that a new axle, also includes new bearings. I'm very relieved to know that, with new tires, I now have a totally 'new' running gear for my 'senior-aged' FGRV
bullfrogeh is offline   Reply With Quote
Old 12-28-2016, 03:16 PM   #9
Yeah. I'd say if the axle is bolted to the frame, changing the whole thing would be my first option. If it is welded, as mine is, changing it would require I think removing the body first, then some tricky cutting and welding. Some of the members have done this sort of thing. But, since my suspension seems okay, I'll probably go the "easy" route.
brakes, trillium
Where to buy wheel bearings and seals for a 1975 Trillium 1300 Roadsterrv Towing, Hitching, Axles and Running Gear 5 10-02-2015 11:32 AM
Bearings and seal size for 79 Trillium ? Wayne Dirkson Problem Solving | Owners Helping Owners 0 05-22-2009 06:47 PM
Wheel Bearings and Hot Water Heater Lisa M. Care and Feeding of Molded Fiberglass Trailers 10 03-11-2008 11:58 AM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
bearings and grease and antifreeze Chris Z Problem Solving | Owners Helping Owners 6 02-27-2006 07:52 AM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
