I have been towing a newish
Scamp 13 with a 2012 4Runner using a 2" drop ball mount (in a 2" receiver). I do some camping where I have to move around from spot to spot, so getting the trailer level enough while connected is an issue for me and it seems like the 2" drop is putting the front of the trailer a bit too low. (Also, I have to be careful going small bridges where the jack comes close to hitting the ground.) So I was going to get a straight (zero drop) ball mount and try that even though it might be slightly too high. But then I ran across the Curt 40047 Rockball cushion ball mount. If I understand correctly, that would add a vertical inch to my current ball mount, which might be enough. And I guess there could be the added benefit of smoother towing?
Does that seem like a good idea, to use a rocker ball to add one inch making effectively a 1" drop? Do I understand correctly that that will add an inch of height? I am kind of new to this; advice is welcome. Thanks all!
