Using a rockerball to add 1" of height to my ball mount? - Fiberglass RV
Old 06-04-2021, 03:00 PM   #1
Trailer: scamp 13
I have been towing a newish Scamp 13 with a 2012 4Runner using a 2" drop ball mount (in a 2" receiver). I do some camping where I have to move around from spot to spot, so getting the trailer level enough while connected is an issue for me and it seems like the 2" drop is putting the front of the trailer a bit too low. (Also, I have to be careful going small bridges where the jack comes close to hitting the ground.) So I was going to get a straight (zero drop) ball mount and try that even though it might be slightly too high. But then I ran across the Curt 40047 Rockball cushion ball mount. If I understand correctly, that would add a vertical inch to my current ball mount, which might be enough. And I guess there could be the added benefit of smoother towing?
Does that seem like a good idea, to use a rocker ball to add one inch making effectively a 1" drop? Do I understand correctly that that will add an inch of height? I am kind of new to this; advice is welcome. Thanks all!
zack sc is offline   Reply With Quote
Old 06-04-2021, 03:29 PM   #2
North Dakota
you have lots of options
The rocker ball will raise you about one inch, and will give you lots of cushion from jerking. A different ball mount is an option. An adjustable ball mount is another option. The are 2 inch balls that are different height also.
hghsl is offline   Reply With Quote
Old 06-04-2021, 05:48 PM   #3
AC0GV's Avatar
Wisconsin
Many ways to do it.
One or 2 inch ball lift? Part numbers on picture.
AC0GV is offline   Reply With Quote
Old 06-04-2021, 06:53 PM   #4
Trailer: scamp 13
Thanks a lot!
Thanks. These comments are really helpful. I did not know about these options.
PS. I spoke to a guy at e-trailer today, and he did not seem aware of these options either (surprisingly).
Old 06-06-2021, 06:29 PM   #5
Trailer: Trail Cruiser
I like the adjustable height configuration. Much more versatile and I have several trailers.
Mike_L is offline   Reply With Quote
Old 06-06-2021, 07:19 PM   #6
Check the ratings of the ball that gives a height boost as they usually have lower towing limits.
Scamp 19 Hitch cushion (Curt rockerball hghsl Towing, Hitching, Axles and Running Gear 5 05-14-2021 08:07 PM
A "no drop" ball mount? ZachO Towing, Hitching, Axles and Running Gear 27 05-15-2016 08:06 PM
Ball Height LizP Towing, Hitching, Axles and Running Gear 6 04-26-2009 07:20 PM
1995 B17CB Bigfoot - Ball Height Dave R Towing, Hitching, Axles and Running Gear 2 08-02-2008 09:20 PM
Reversing the Shank to Increase Ball Height MikeC Problem Solving | Owners Helping Owners 5 03-26-2008 07:25 PM
