wheels for My trailer - Fiberglass RV
Old 01-21-2006, 06:03 PM   #1
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Since it looks like I will be replacing my Van with an almost Identical match, I had a little brainstorm ( everybody grab umbrellas, it might get messy)
The new van has the same wheels as the old one. The bolt pattern matches.
see where I'm going?
The problem is I don't know if the Gm factory aluminum rims will handle the trailer weight.
The engineers at GM wouldn't commit to an answer when I got in touch with them.
The wheels are 15 by 6 Cast aluminum, and would look great on the trailer, but would the trailer weigh too much for them?
anybody got an opinion???
Old 01-21-2006, 06:52 PM   #2
Con
Trailer: 1977 Boler 1300
Joe, I wouldn't even give it a second thought, fly with it!
We have alumnium wheels on our horse trailer and all 4 Chevy trucks we have leased and never had a bit of trouble. Even with two horses in the trailer they showed no signs of stress. Our horses were about 2200 lbs together. Mind you that is a dual axle. The wheels made now adays are so much better that they used to be. Years ago I talked to a number of people who had them crack.
One of the problems I found though, was that the shops were torquing the bolts too tight with the impact wrench thereby over stressing the wheel. Finally some one published some proper torque tables for alumnium wheels but you still have to watch these guys. I used to get into some arguements with some of these guys.
As a matter of fact when I designed a indepedent front suspension system for my friend who builds street rods, during my research into all the geometry involved, one of the things that seemed to keep cropping up was to keep the suspension sprung weight of down. One way to do that is to use lighter wheels. eg: alumnium wheels. It also helps your gas milage a whee bit.
Con is offline   Reply With Quote
Old 01-21-2006, 07:08 PM   #3
Frederick L. Simson's Avatar
Talking
Is your trailer heavier than 1/2 of your minivan? By how much?
Old 01-21-2006, 07:41 PM   #4
Brian B-P's Avatar
Following the same logic as Frederick implies, I would check the axle capacites. My Sienna (a pretty typical current minivan) has the same axle rating front and rear, which is almost as high as the 3500 lb rating on my B1700 axle, and about equal to the maximum to which Boler rates the axle to be used. I don't know either the highest axle rating of Joe's GM van (the wheels must be strong enough for that), or the maximum axle loading of the Trillium 5500, but that's the comparison I would make.
I have had the same thought regarding my Sienna and Boler; however, while the bolt pattern is the same for both vehicles (5 on 4.5" or 114 mm), the offset and centre hole size are incompatible - the van wheels will not fit the trailer properly. So much for my excuse to upgrade the van to 17" wheels! That's a couple more things to check...
Given a choice, I would always use factory or good aftermarket aluminum alloy wheels rather than steel, on any vehicle under any condition. While my trailer wheel experience is limited, my preference is based on hundreds of thousands of kilometers of street use and some competition experience. Decades ago, poorly made alloy wheels gave them all a bad name, but I agree with Con that this is not a current problem.
(Edit is just a typo fix)
Old 01-21-2006, 10:18 PM   #5
Roger H's Avatar
I don't think you'll have any problems using automotive use wheels on your Trill. As they are alloy, though, you'll need to regularly make sure your wheel nuts are properly torqued so as not to have one of your trailer wheels pass you while you drive down the road one day!
Alloy wheels tend to loosten their lug nuts regularly. I retorque those on my Airstream before every trip, and I tend to check them after the first couple of hours on the road during each trip. It's amazing how much they'll loosten up.
Roger
Old 01-22-2006, 08:17 AM   #6
BobB's Avatar
Joe,
Look in the owners manual or on the driver door post of the van for the original tire weight rating. The weight rating for the original wheel should be pretty close. Be sure to use the wheel nuts designed for the aluminum alloy wheels. I don't know if you should change the studs. If the wheel nuts won't stay tight with your new setup, I would be inclined to go back to the original wheels on the trailer. A torque wrench is a good thing to have--you want 90-100. You shouldn't have to tighten the wheel nuts repeatedly. Good luck!
BobB is offline   Reply With Quote
Old 01-22-2006, 08:40 AM   #7
BobB's Avatar
Afterthought: I should have said the studs on the trailer might not be long enough, since the alloy wheels are probably thicker. You want all the threads on the wheel nut to engage the stud. Studs can be changed, but this could be a challenge if there is much rust.
Old 01-22-2006, 08:51 AM   #8
Rob S.'s Avatar
Trailer: 1980 Bolar 1700
Joe,
My guess is that you would be perfectly fine. I am assuming that you plan to replace the tires with properly rated trailer tires and are not planing on using the car tires. I did a little searching around an did find a useful link about wheels and one key thing would be to remove one of your wheels to see if there is a load rating stamped or cast on one of the spokes of the wheel. With that information you do the math, if 1/2 of your total GTW is less than the max rating on the wheel you are golden. The concern you have is valid. GM put 4 wheels on the van taking into consideration that the total gross would be divided by 4 not 2. The other thing you could try is to take them down to your local Tire Shop and ask them. You will have to factor in your trust level of their opinion of course.
Good luck.
Rob S. is offline   Reply With Quote
Old 01-22-2006, 11:25 AM   #9
You`d think that any wheel supplier like a speed shop should be able to look up different mag/aluminum wheel weight capacity ratings in different size wheels.....being from snow country I`m not a great fan of aluminum wheels as I have them on both my trucks and because of salt usage on the roads, the wheels corrode rather rapidly and also develop rim leaks a lot more often than steel wheels due to the corrosion....of course the RV`s aren`t used much in salt conditions so that may not be a problem......on my trailers I prefer steel wheels with full discs because of less maintenance......Benny
Old 01-22-2006, 01:28 PM   #10
I'll check the ratings when I get home , never thought of that.
I live in snow/salt country too, and yes the rims do corrode if you don't keep them clean.
I've only had two rim leaks in 10 years, and the local tire shop fixed both of them.
They pulled the tire off the rim, wire wheeled the rim, buffed the rim and applied a high quality enamel to the inside edges. Let it dry, remounted the tire and Bob's your uncle.
I really do have an uncle Bob by the way.
Old 01-22-2006, 02:11 PM   #11
Brian B-P's Avatar
I understand the concerns about corrosion with alloy wheels, but I see a lot more on my steel wheels than my alloys. I have had no problems with surface corrosion at all and no need to clean up bead seating areas so far. To some extent I am seeing the benefit of well-made OEM (original equipment on the car) alloys, but more significantly, for cost reasons I tend to use cheaper steel wheels for the winter tires and the alloys in the summer (we currently have three vehicles in that mode). As Benny says, trailers are generally for summer use anyway. Most people in Edmonton do not change to winter tires so they use their original alloys year-round, and I have not noticed that complaints are common. If cost were no object, my Boler would be on alloys now, but I suppose salt-induced corrosion may be a factor to consider.
Old 01-22-2006, 05:16 PM   #12
Con
Youare right about alloy wheels Brian. The big mistake I made when we Bought our Featherlite all alumnium trailer was that I did not specify the alum. should be clear coated. As ot happened we have had to deliver a llamas in mid Dec. when the roads where heavily salted. The road salt played hell withthe finish. The alloy wheels on our pickups however have been coated with a baked on clear polyethlene finish which prevents that kind of damage.
So if any of you do by new alloy wheels, make sure they are clear coated. Like Winnipeg , our roads get heavily salted. I gave up on painted steel snowmobile decks and trailers as they would start rusting after one trip out.
Old 01-22-2006, 07:39 PM   #13
My corrosion problems usually started where they used the plastic coated weights to balance the wheels and when the tires were replaced and the tires were rebalanced....the places where the weights were are always corroded.....used to use the stick on weights on the inside of the rims but that system wasn`t as precise as regular weights on the outside....it`s whatever you wish......if the wheels are really looked after there should be no problem......Benny
Old 01-22-2006, 08:16 PM   #14
Dan Quinn's Avatar
no problem go for it.....
Dan Quinn is offline   Reply With Quote
Old 01-22-2006, 11:30 PM   #15
Lance MacArthur's Avatar
Trailer: Boler 13 ft 1972
We changed our 13" rims for 14" rims rated for trailer use in our Boler awhile back. Put on trailer rated tires. We were about half a mile out of the tire place when a pickup honked at us saying smoke was coming from the trailer. We stopped right away, and found that the new trailer tire, with its additional flex, was rubbing against the wheel well, causing everything to heat up and melt. It was so hot that the rubber bonded itself to the wheel well.
All this to mention that the inset of rims vary, moving the tire some. In our case, too much. Didn't notice it when it was being put on, as there was no weight on it, and it spun freely. Also, the tire flex varies by type and tire height, so if your clearances are minimal, check things carefully.
Luckily, we had no fire, and the damage was minimal once we got the mess cleaned up. We switched to a flatter automotive radial tire, and have had no further problems, with more than 20,000 miles of travel in two years. The tire folks say there's not a lot of difference in trailer tires and automotive tires; trailer tires have stuff in the sidewalls that prevent uv damage, and they're built to flex more.
Bottom line -- check everything carefully before you drive off.
Lance MacArthur is offline   Reply With Quote
Old 01-22-2006, 11:40 PM   #16
Dan Quinn's Avatar
lance your problem was caused by going to a 14 in rim not the tires..always use trailer tires or even a truck tire but never use car tires...
Old 01-23-2006, 07:01 AM   #17
Steve L.'s Avatar
A minor observation: The load calculation formulas say that trailer tires carry less weight per psi than a passenger car tire used on a passenger car and so for the same size tire the trailer tire will deflect less.
Your tire adviser is correct if you also remember to "de-rate" the capacity of the passenger car tire by 10%. Passenger car tires used in an application for which they were not designed (trailer usage) are supposed to carry 10% less weight for a given pressure. Carrying the 10% less weight brings the deflection nearer to that of a trailer tire of the same size. The "supposed to" portion of this comes from the Tire & Rim Assn. who are the people who publish the load/inflation tables we use in the U.S.
FWIW, not much (none) of the load in a "normal" tire (not counting the run flat types) is carried by the structure of the tire.
Without adult supervision...
Also,
Old 01-27-2006, 10:30 PM   #18
Doug Mager's Avatar
Trailer: 1975 13 ft Trillium
New wheels on out Trillium are 14in Ameriacn Racings Torque Thrusts and I am using 6ply tires which I had on two of my other import trucks when needed in times I knew I'd be packin some extra weight (other than my own ( ). The wheels also appear on our tow vehicle, a '37 Plymouth 4 door Hot-Rod. Makes a statement sitting still or travelin on thr open roads. I have experienced NO problems at all in the last season I had them installed.
Old 01-31-2006, 08:40 AM   #19
Trailer: Love Bug / Chevy Astro
I have a question for you Joe. Do the wheels from your GM have the same bolt pattern and hole size as your camper? I thought that the GM wheels were different. If they are different, you may be able to change the hubs on the camper to get them to match up.
Bob Cupp is offline   Reply With Quote
Old 01-31-2006, 09:44 AM   #20
by my measurement they are 5 on 4-1/2, same as the hubs on the trailer.
when it quits snowing and gets warm, I'll let you know.
Joe
Fiberglass on 4 Wheels Mac B Modifications, Alterations and Updates 12 11-19-2009 08:47 PM
Two 14" 5 Lug Trailer Wheels from Scamp Camper ($30/pair) - Greg A Classified Archives 0 04-01-2009 10:53 PM
wheels jmacchi Problem Solving | Owners Helping Owners 9 01-19-2009 02:24 PM
Wheels Legacy Posts Problem Solving | Owners Helping Owners 4 08-07-2003 08:07 PM
