ON SOLD: 1977 Trillium 4500 Deluxe 15ft located in Oshawa Ontario Canada - Fiberglass RV
Old 02-14-2018, 07:04 PM   #1
Treeax's Avatar
Trailer: 1978 trillium 4500
$9,000 Cdn or $7,000 USD
Layout has the rear dinette and front gaucho. Windows all around including door and kitchen.
Rear Dinette converts to a 48” double bed. The Front Gaucho is a couch and converts to a bunk bed.
Less than 2000 lbs dry, towable with most vehicles. Interior height 6’2”. Sleeps 3 adults, or 2 adults and 2 kids.
Have the ownership, 2 keys and the original Owners Manual.
Furnace propane – works – Duo-Therm 65810-2 Model – Gravity style - 7,000 BTUs - radiant style heat, no blower – excellent working condition. Original operating instructions included. Has been sandblasted and powder coated black.
Range – 3 burner propane stove. Has been sandblasted and powder coated black.
Fridge – works - Dometic RM211TF – 3 (or 2?) way fridge – we have only used on propane. Very cold! Height 22”, width 19” depth 17” = 2 cu ft. Has a small freezer with an original ice cube tray.
Power Converter – Progressive Dynamics PD6911 – works. Converts 110v to 12V
Sink and Faucet – stainless steel – Sink and drain pipe intact. Faucet removed but still have all the pieces. Coleman 2231 pump style hand pump. Has city water connection. Sink and counter is covered with a countertop.
Fresh water holding tank and pipes – were removed. The space under the dinette (where you put your feet) is now used for storage for light things such as blankets. Could likely be reinstalled if really wanted to.
Curtains – new - beige with black out fabric. Curtain on door windows and one for kitchen window as well.
Wall Sockets – two double plugs 110V located on back wall and dinette/kitchen corner. Single 110V plug located on the converter at floor.
Lights – AC/DC. All new with LED bulbs, including the porch light. Missing cover on large original kitchen light.
Outdoor running lights and brake lights all new and working order. The brake lights are LED.
Fantastic Fan ventilation fan – new AC/DC power fan replaced the old roof vent. Three speeds.
Lots of storage – 4 drawers under dinette. 2 drawers under gaucho. Plus open storage accessible under dinette benches and front couch. Storage under sink. 3 drawers, with the cutlery drawer under the table. Large closet with new 4 shelf pantry and closet rod. At entrance there is another cupboard. Overheads have lots of open and covered storage.
Awning C-track – no awning.
Frame – the body of the trailer was lifted off the frame in 2016. The frame was sandblasted and re-painted black. A new tongue with 2” ball was welded on. Also two new stabilizer jacks at the rear of the trailer were welded on.
Axle – new 3500lb axle. EZ Lube bearings. Includes the brake plates, just add the brake system and power if you want brakes.
Tires – New tires purchased in 2016.
Rims – New aluminum rims purchased in 2016
Spare tire – with tire cover, and mounted to the back bumper.
TV – comes with new swing arm and long cable line. Doesn't include actual TV.
Table cushions – new, uncovered. 4” thick high.
Flooring – currently this is just carpet lying over the fiberglass flooring. Can change to match taste. Annually we usually purchase a 4x6 carpet with rubber backing and cut it to size. The cut out corner fits nicely under the table.
Belly band was sealed and recovered by the prior owner
Decals – new decals installed on outside of trailer by prior owner
New propane hoses. The regulator is still original.
Windows – were all removed and the wooden frames replaced and resealed.
Table – converts to a bed. When in the table position, it has a removable leaf to have a 2 person table with easier access to the benches. Where the leaf attaches, some of the wood near the dowels is worn. And some of the clasps underneath are broken. This would have been our next project if we kept the trailer. The issues with the table are listed to give you honest information, but it does not interfere with the function of using the table as a table or bed support.
Access panels – all new and sealed.
Selling because we are getting a bigger one. We just spent two weeks living in this trailer in Florida at Christmas.
Battery or propane tanks NOT included.
Email and/or Phone: 4500TrilliumON@gmail.com
Trailer Location: Oshawa Ontario Canada
Treeax is offline
Old 02-14-2018, 07:08 PM   #2
mccartan's Avatar
Trailer: Trillium 4500
ID:	115858Click image for larger version
ID:	115859Click image for larger version
ID:	115860Click image for larger version
ID:	115861Click image for larger version
ID:	115862Click image for larger version
ID:	115863Click image for larger version
ID:	115864Click image for larger version
ID:	115865Click image for larger version
ID:	115866Click image for larger version
ID:	115867Click image for larger version
mccartan is offline
Old 02-14-2018, 07:08 PM   #3
mccartan's Avatar
ID:	115869Click image for larger version
ID:	115870Click image for larger version
ID:	115871Click image for larger version
mccartan is offline
Old 02-14-2018, 07:16 PM   #4
mccartan's Avatar
[/ATTACH]Click image for larger version
ID:	115874Click image for larger version
Gel coat in excellent condition. Freshly waxed in January.
mccartan is offline
Old 02-14-2018, 08:51 PM   #5
Trailer: Trillium Jubilee
New Jersey
Hi my friend
Where are you located?
Thank you
Falicea is offline
Old 02-14-2018, 08:57 PM   #6
Trailer: 1975 Trillium
Would love to come see it. Can you private message me? Where exactly are you located in Ontario?
Thanks,
Kaddie
openthegates is offline
Old 02-14-2018, 08:58 PM   #7
mccartan's Avatar
Oshawa Ontario Canada. It’s the very last line of my very long post!
mccartan is offline
Old 02-15-2018, 07:00 AM   #8
very nice
nice looking camper good luck on your sale
bob
k0wtz is offline
Old 02-15-2018, 07:06 AM   #9
Treeax's Avatar
bob
Thanks! We are sad to part with it. It was well loved. But we outgrew it and upgraded to a 17' Bigfoot.
Treeax is offline
Old 02-19-2018, 01:50 PM   #10
mccartan's Avatar
Adding pictures of storage and tv mount Click image for larger version
ID:	116011Click image for larger version
ID:	116012Click image for larger version
mccartan is offline
Old 03-01-2018, 05:44 AM   #11
Treeax's Avatar
Due to the falling Canadian exchange rate (or is it called rising?), the USD price is $7,000.
This trailer has all major repairs done... new axle, new bearings, new rims and tires, sealed windows and belly band. Gel coat in excellent, well cared for condition!
Treeax is offline
Old 03-01-2018, 08:38 AM   #12
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Great camper!
With all those improvements (new axle/bearings/wheels/tires, sand blasted frame, new coupler, new converter, etc, etc) your camper is well worth $7,000 usd and then some. Good luck!
John in Michigan is offline
Old 03-01-2018, 08:48 AM   #13
kitchen light covers
As mentioned, the kitchen light cover is missing. The kitchen light actually uses 3 square plastic covers of the same type used in all the other interior light fixtures. There are a total of 7 interior light covers which can be purchased at Amazon, etc. The brand is Progressive Dynamics; the covers are 5"x5".
Old 03-01-2018, 08:59 AM   #14
mccartan's Avatar
Thank you! This is a great tip! We have already replaced all the other covers with this same 5x5 cover. We were able to pickup locally from a camping store. We will pickup 3 more to cover the kitchen light! Thanks again.
mccartan is offline
Old 03-01-2018, 12:46 PM   #15
Of course you can test fit with shades that you've already purchased for other fixtures. On my Trillium 4500, the same shades are used.
Old 03-02-2018, 11:30 AM   #16
Administrator
Mary F's Avatar
Moderator’s note: new USD price ($7000) is now stated in original post.
Good luck on your sale!!
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Mary F is offline
Old 03-06-2018, 05:55 PM   #17
mccartan's Avatar
Your suggestion worked great!! [emoji1303]
mccartan is offline
Old 03-06-2018, 07:58 PM   #18
Hopper's Avatar
Indiana
I love this Camper! Do you still have it for sale? What is it’s dry weight? I would come pick it up if it’s the right weight for my car.
Hopper is offline
Old 03-07-2018, 06:03 AM   #19
Treeax's Avatar
Pending Sale
Hi, this trailer is pending pickup on Friday. I will let you know.
Dry weight I noted above as being under 2,000lbs. Whatever the standard Trilliums are... there are no major modifications on the trailer to affect the weight.
Treeax is offline
Old 03-07-2018, 07:38 AM   #20
Hopper's Avatar
Indiana
Thanks, let me know if she does not sell.
Hopper is offline
trillium
ON | SOLD 2005 Bigfoot 25B17.5G Located in Southern Ontario Don Dunsmore Classified Archives 16 12-23-2015 02:15 PM
15ft beachcomber for sale in ontario Lori-Ann Classified Archives 4 02-05-2007 04:08 PM
