This highly modified
Bigfoot (which was once a coffee truck) has one full time bed 80x48 (which has a foam mattress) one L shaped bench or bed (no mattress) 75x45 (bed dimensions) or leave it as a bench full time and put the awesome wood stove back in (easy install with chimney and vents still in place) - HUNTERS DREAM!!
The trailer has a double sink and running cold water, (there is a hot water storage tank but the heater gave out and we didn't bother replacing) a toilet, and a
furnace that works great! There is a new converter, a breaker box and also a fuse panel and
propane detector.
There's lots of storage under the main bed, under the sink and in the closet.
Outside - has an
awning, stabilizing jacks, newer trailer
tires (2015), spare tire and equipment deck off the rear. The axel is flipped for better clearance.
Propane and batteries mounted on the frame in front of the trailer. Bearings and
brakes done last summer. Has electric
brakes which work well. The roof has some sag but
fiberglass is not compromised no
leaks and doesn't affect use.
Newer curtains and
paint and many window and roof seals redone in 2015. This trailer is dry and comfortable and has no funky smells.
Use as is or customize to your liking (I thought I'd make a table for the bench seat and plumb an outdoor shower...
. Add a bar
fridge?
Only upgrading as the family has grown and we found a 21.
4800.00 obo
https://nanaimo.craigslist.ca/rvs/6215328034.html (link is external)
Upgrademycamper(at)gmail(dot)com
Cheers
Trailer Location:
Ladysmith B.C
