Carry canoe on top of trailer - Page 2 - Fiberglass RV
Journey with Confidence RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 07-06-2018, 11:38 PM   #21
tractors1's Avatar
Trailer: Escape 21 - Felicity
I wouldn't be concerned about the weight of a canoe on the trailer as they're a whole lot lighter than a human being and a distributed load. I'm pondering how the heck to get one up there, particularly with an A/C and vents along the centerline. I put a boat roller on the rear of my pickup camper and it was still a challenge to roll a 17 ft canoe on top, then tie it down on one side of a flat roof and lash it down to wide Yakima rails.
Charlie Y
Old 07-07-2018, 09:48 AM   #22
Trailer: 93 Burro 17 ft
The weight wouldn't be the problem, but now that I think about it, it's how tightly you'd have to tie it down. This would force the canoe downward and might deform the Trillium's shell under the blocks (which would loosen the straps or ropes while traveling). Not so good.
Hmm, what about welding a rack overtop the roof? Support the rack with vertical pieces welded to the A frame and the bumper. Canoe would not touch the shell at all. Seems like I saw a picture one time of someone's trailer where they'd done this.... must've been close to 10 years ago, no idea who.
Old 07-07-2018, 10:23 AM   #23
A Uhaul camper owner built a rack system that attaches to the trailer frame and goes over the roof to carry two kayaks. Almost looks like a roll cage on the trailer. They did a nice job, but looks like a lot of lifting to get the kayaks up there. As for the comment about a rear bike rack damaging the bumper, if you're going to carry bikes on the rear you have to build a good receiver hitch that goes under the trailer and attaches to a couple frame crossmembers, not just the bumper, and use a rack that is rated for use on a RV. Plenty of threads here about rear bike racks, and the pros and cons of using one.
Old 07-07-2018, 06:23 PM   #24
tractors1's Avatar
Excellent point! This retired mechanical engineer definitely agrees.
Charlie Y
Old 07-07-2018, 08:22 PM   #25
Trailer: '15 17' LD Casita and '17 Tahoe LT
If you carry it on the trailer, at some point I would become worried about clearing overpasses, etc. Just thinking...
dmad1 is offline   Reply With Quote
Old 07-07-2018, 10:34 PM   #26
Trailer: Thinking really hard
I've seen at least two trailers that had a "hitch" with a bike mount. Just make sure the hitch is bolted/welded to something stout enough.
I also saw a guy who had two bikes mounted on the tongue of his Airstream, but he was dragging it with a F350 so weight on the tongue probably wasn't an issue.
dmpyron is offline   Reply With Quote
Old 07-07-2018, 10:52 PM   #27
Saskatchewan
I went to my local metal yard today and was able to pick up this beautiful 2”x2”x120” piece of hollowed stainless steel. Used my angle grinder to cut it into two 60” cross bars. Drilled holes spaced evenly to fit over my stock rails and secured with 2” u-bolts. It is solid as a rock and will have more than enough room for all my toys.
Metal yard purchase: $21
Hardware + drill bit: $34
All said and done I’ve got a solid roof rack for $55
Thanks again for all the help! I’m confident in my choice and so relieved that I will not have to worry the entire time we’re on the road that I am causing damage to our trailer. Fringe benefit, I don’t have to carry our boat to the launch.
E868DDA9-5957-4BF9-A9F3-2DC79400FD17.jpg   5ABF5958-A1CF-44D7-BFB2-A86D7CD45977.jpg
AEC5A3F9-4D8D-4179-BD30-E6976A1468D4.jpg   4BA4186E-732A-42F5-8C44-8B45EACF55A5.jpg
DevMT is offline   Reply With Quote
Old 07-07-2018, 10:53 PM   #28
Saskatchewan
I’ll post more photos when I have the whole rig set up.
Old 07-08-2018, 12:32 AM   #29
John in Santa Cruz's Avatar
Mid Left Coast
long as you're not over 12' tall, you're good almost everywhere.
Originally Posted by dmpyron View Post
I've seen at least two trailers that had a "hitch" with a bike mount. Just make sure the hitch is bolted/welded to something stout enough..
I've got a bike rack on the hitch reciever thats on the back of my Escape 21. reciever says "Max load 150 lbs", my bikes weigh maybe 50-55 lbs combined, and the RV rated Swagman Escapee2 rack weighs maybe 30 lbs, so we're well under that. not worried about the tongue weight at all, but I'm towing with an F250 diesel longbed...
Old 07-20-2018, 05:07 PM   #30
Saskatchewan
Final Product!
Here she is in all her glory! Worked beautifully. Thanks again for the advice!
9555AA00-56AF-4919-9CFD-453FE50CC6DA.jpg   F76FF309-8D90-493C-A349-C3262D0A4A22.jpg
Old 07-20-2018, 06:01 PM   #31
Trailer: Parkliner 2014
I like it!
Do you have a total height? My canoe would probably be under the 9' on the trailer, but I'd probably forget the extra height at just the wrong time.
FishingBob is offline   Reply With Quote
Old 07-20-2018, 10:08 PM   #32
Saskatchewan
Originally Posted by FishingBob View Post
I like it!
The canoe is lower than the trailer, I can actually drive it into the garage with at least 4” clearance. As for the bikes I’m not sure. I’m not driving anywhere a semi wouldn’t so I think I’ll be safe.
Carrying a canoe while towing a trailer; recommendations? Des Nolan Towing, Hitching, Axles and Running Gear 8 10-16-2010 05:43 PM
Neat motorcycle/camper/canoe concept Raya General Chat 10 11-21-2009 06:26 PM
inflatable boat/canoe artspe General Chat 9 12-16-2008 09:49 PM
Canoe - Kayak Rack Pete Dumbleton Problem Solving | Owners Helping Owners 0 07-28-2007 04:02 PM
Canoe / Kayak Trip - the Lower Coquille River robin marshburn Oregon Gatherings 0 07-18-2007 06:32 PM
