Thank you for the picture. Some observations:
1) You will need a front rock guard. The original ones are very hard to find, but Joe Thoen at Trillium / Outback, (
https://trilliumtrailers.com/) sells a fibreglass version with gas struts. It's not on their parts page, so it is probably expensive.
- On edit, (I hit post after you posted more pictures).
I see that you do have the rock guard. However, I don't see the frame that the guard mounts to. It is a U-shaped partial frame that includes the sides and top, but not the bottom. If you don't have that, I can send lots of pictures of what it looks like. Maybe you can recreate it from aluminum angle. Or is it still installed on the outside of the front window?
2) The fact that you have a roadside logo on your trailer indicates that you have an icebox, not a
fridge. If you install a 12VDC compressor
fridge, you don't have to destroy the logo.
3) It looks like your trailer had a
furnace, but, since the exhaust hole is cut below the step in the side, not the factory Duo-Therm 65512-2. I'm a bit of a nut, but were I you, I would fix the exhaust hole and install the Duo-Therm gravity
furnace. They are still
sold second hand. They’re not very efficient, but there are no
electrical requirements.
More observations for the new pictures:
4) Your Ensolite is detached in places. This can easily be fixed. Detach it till there is a flap. Clean it and the fibreglass.
Paint with contact cement. Follow the instruction to wait till it is dry then reattach at the furthest point first and smooth it into full contact with the fibreglass shell. Ensolite is, in my opinion, the best insulation for fibreglass trailers. It well worth saving.
5) The seams between the Ensolite pieces is warped. Also easily fixed. Pull it off, (it snaps back on) and boil it. This will soften it up and allow it to be flattened out.
6) No door on your closet. Is it anywhere? The reason I ask is that on the inside of that door is where the data sheet for the trailer is found. I would ask that you post a picture of that data sheet. I have a bit of a resarch project regarding Trillium serial numbers:
https://www.fiberglassrv.com/forums/...tml#post680419
7) You will need new foam and a cover for the back of the front bench / upper bunk, (the poles in your closet are the supports for the upper bunk). I can give you the dimensions of the foam for that.
8) Your fire
escape window is screwed shut. Not much of an
escape route.
Other than those observations, there are five items that all Trillium restorations involve:
1) Window frames: The wood on the inside of the trailer, that the
windows are screwed into, are exposed to condensation and commonly rot. The wood is ľ" plywood. Nothing special. If it is rotted, then it easily separates from the Ensolite. If it is not rotted, I would just leave it.
I did a thread on this:
https://www.fiberglassrv.com/forums/...ead-65342.html
2) Mounting Bolts: The six bolts that hold the coach to the frame will need to be replaced. Most will have rusted through, or nearly through. I replace them with stainless steel bolts and stainless nylock nuts with nylon washers to prevent galvanic corrosion. I also install them with the nuts inside the trailer and the heads of the bolts on the outside. This is to keep the threads out of the weather.
3) Trailer
Axle: The torsion
axle on Trilliums lasts about 20 years. After that it either collapses as the rubber in the
axle crumbles, or the rubber hardens and no longer flexes. Either way, a new one is in order. I would go with one that has
brakes.
4) The Door: The door is screwed into thin sections of plywood that have rotted out long ago. There are several approaches to this. Currently my preferred method is to drill a ˝" hole where screws go through the body and fill that space with resin and fibreglass, to give new screws something to bite into. Maybe use plastic screw anchors for something softer for the screws to screw into.
5) The Belly Band: This is the biggest job. The way that Trillium joined the top and bottom halves of the trailer is with metal plates inside the trailer that the belly band rivets into. Once the top and bottom halves line up, Trillium ran a strip of fibreglass and resin over the metal plates on the inside. In time the plates rust out, or multiple freeze thaw cycles cause water caught in the pocket that the metal plate sits in to expand and slowly rip the fibreglass till it
leaks into the inside of the trailer. I have done a couple of threads on the repair that I did:
On a 1300:
https://www.fiberglassrv.com/forums/...ead-58763.html
On a 4500:
https://www.fiberglassrv.com/forums/...ead-59580.html
I hope that helps.
