Yep, that's bad. First things you want to check is the frame, the tube sections rot out. Then check the floor, and learn about the window issues. Then on to all the odd stuff about these trailers. And before anyone says to grease the wheel bearings, they are sealed units and can not be serviced. Also these trailers did not have
brakes and they can't be added unless you replace the
axle.
