Hi! I am Ashley, vintage Trillium owner! - Fiberglass RV
Old 05-08-2020, 06:21 AM   #1
Hi all! New member here. My family bought a 1979 Trillium in February. Looking into a few upgrades like closet shelving and pulling out the fridge. Any tips/suggestions are very welcome!
tinycamper_bigfun is offline   Reply With Quote
Old 05-08-2020, 06:28 AM   #2
Address the design defects first: belly band, window remounting, frame to body bolts, door hinge mounts are some of the more common ones. Replacing the 40+ year old axle and power center are also common projects. Endless threads on people successfully completing those repairs if you go to the manufacturers section to the upper right and pick Trillium.
If you can revive the refrigerator, I would not pull it as its an odd size and new ones do not fit (OK, they can be installed, but they stick out into the aisle way which is less than ideal IMHO).
In this time of social distancing and isolation, it can be a great time to do projects.
If you don't address the deficiencies early on, you risk damaging the trailer and for me at least, running out of enthusiasm to complete the project. Everyone enjoys doing the cosmetic stuff. Meanwhile, progress on the structural stuff doesn't show as much.
The Facebook Trillium trailer page has been very active lately.
Love my old Trillium!
thrifty bill is online now   Reply With Quote
Old 05-08-2020, 08:26 AM   #3
thanks
Thanks! Luckily, she's in great structural shape thanks to the previous owner. We are taking the fridge out bc we won't be using it and need more storage space. Any tips on how to remove?
Old 05-08-2020, 08:50 AM   #4
Steve Hammel's Avatar
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
If you take out the fridge store it don't get rid of it because it will lower the value of the Trillium. If you have it at least it can be reinstalled. Get a flare nut to close the gas line and you should be good.
I like to use fragrant cedar to make shelves for older trailers. It is light, thin and easy to work with.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT
Old 05-08-2020, 09:28 AM   #5
Great. Thank you! We will def hang on to it. We just don’t use it. Too small for what we need. Cabinet storage/ pantry items is what we’ve been using it for. And there’s just not enough space.
Old 05-09-2020, 08:05 AM   #6
Trailer: 1978 Boler
Almonte, Ontario
Since the Trillium and the Boler were laid out in the same basic floor plan, a closet solution would be the IKEA Trofast hack.
Now, I’ll start with: I did not use the Trofast unit but just the bins in my closet remake. But there are several other approaches.
One approach would be to buy the correct height Trofast unit and assemble it inside the closet (but not the way IKEA wants you to). You will need to adapt the wall pieces to fit the closet space, on the inside surface of the unit, drill angled screw holes in the top, (middle, if it comes with) and bottom pieces, chip out the dowel holes on the other side of these pieces, insert dowels into the wall pieces and slide the top up and screw in place, repeat with the middle piece, if there is one and the bottom piece. Now you have the unit in place. Now you can do the adjustments to level and secure in place.
Another option is to build a unit from scratch using U-channel for sliders. This is how I built my unit but that was because I had just learned a spectacular boatbuilder’s trick and wanted to use it.
Nicolas is offline   Reply With Quote
Old 05-09-2020, 08:38 AM   #7
Cool. Def something I’ll look into. Thanks!
trillium, vin
Vintage Trillium parts Alf S. Problem Solving | Owners Helping Owners 25 08-04-2016 11:05 AM
Rich and Ashley's Uhaul CT Tuanis Modifications, Alterations and Updates 15 04-27-2014 11:09 PM
New Vintage Trillium owner Bananaman Hi, I am.... 9 12-24-2013 02:42 PM
Vintage curtain tracks -- need vintage snaps Mara Modifications, Alterations and Updates 5 05-29-2013 05:50 PM
Vintage 1964 Apache Silver Eagle Orig Owner Documented $3500 jessejames Classified Archives 0 08-25-2010 10:57 PM
