Hi, I'm a new owner of Trillium 1973 - Fiberglass RV
Old 01-07-2025, 01:13 PM   #1
Trailer: Trillium 1973
Quebec
Thank you for this great resource and it is still active for so many years. I have a lot to fix on my little camper. First problem is our fridge, it lights when I hold down the gas flow button, I was told to hold it down for a long time to keep the flow of gas going and then slowly let it go, but, this never works. It just quits every time. Any body have experience with this problem. Thanks!
lisaberntrillium74 is offline   Reply With Quote
Old 01-07-2025, 09:05 PM   #2
Welcome, and congrats on your Trillium! As to the fridge, that sounds like a bad thermocouple. Normally that’s a pretty simple fix, but I have no experience with a vintage model.
Old 01-09-2025, 05:56 AM   #3
Trailer: Boler 13 ft
Welcome to the group and it sounds like your thermo couplin is no good or not in the proper position. To explain, this tube has to heat up and this is what will activate your gas valve to open, you can try this. First look into where the pilot flame is, see if the slender tube looking thingy, IE thermo couple, is where the pilot flame is going to hit it and heat it up when your holding the button in. If so. it is probably not working and it is easy and inexpensive to replace. Another way to test it is to use a propane torch to heat the tube and see if this will open the gas valve to keep the fridge lit.
trillium
New owner of a much loved 1973 Love Bug Barb K in MN Hi, I am.... 2 07-21-2020 10:56 AM
New owner of 1973 Tote ‘n Tarry AubeyG Hi, I am.... 6 10-24-2017 06:11 AM
Hi, I am a new 1973 Trillium 1300 owner Trailereva Hi, I am.... 8 09-04-2017 11:35 AM
I am the proud owner of a "new" 1973 Trillium 1300 Rob L General Chat 7 11-04-2009 11:47 PM
New old owner, or old new owner? drews60 General Chat 7 11-17-2006 05:36 PM
