Hi, I'm Lianee and want to tow with a Honda Odyssey - Fiberglass RV
Old 03-13-2023, 11:10 AM   #1
Trailer: Currently Shopping
I'm looking at purchasing a Trail Mite because it is 13' and would fit into the space available. My car's owner's manual indicates with the proper components I'll be able to tow the trailer.
My concerns center around the future care and maintenance of a 50-year-old fiberglass trailer. It will have to be outside.
Looking forward to searching through the Forum.
Lianee is offline   Reply With Quote
Old 03-13-2023, 11:22 AM   #2
David Tilston's Avatar
Welcome Lianee!
The Trail Mite looks a lot like a Boler to me. Not that I'm much of an expert of either brand. There are several 13' trailers. What is it about the Trail Mite that you find attractive?
I'm a big fan of Trillium trailers. For me that started with the Duo Therm gravity furnace, (no fan) that are typically installed in these. The other major attractions were the fibreglass furniture and slightly more square construction that made them feel larger inside. Though I would recommend the slightly larger, (15') Trillium 4500 vs. the 1300, (13').
I'm also from Canada. Totally different conditions from California. Snow vs. Sun. However I've been known to describe fibreglass trailers as being nearly immortal.
Old 03-13-2023, 11:38 AM   #3
Hi David - I like the space inside and the amount of light through the windows. I'll check out the Trillium. I hadn't heard of them before. I hope there are a few more years left on this one.
Old 03-13-2023, 12:04 PM   #4
Oh, I didn't realize that you already had a trailer. Love the one your with.
As far as checking out Trilliums go, take a look at this thread:
https://www.fiberglassrv.com/forums/...tml#post680419
The last digits of the serial numbers are links to information about and pictures of the trailer.
Old 03-13-2023, 12:18 PM   #5
You have lots of choices in the 13' class, and Trail Mite is the same basic layout as Scamp, Boler, and many others. Trillium is very similar, but a bit more upscale. Scamp is pretty much the only basic 13'er still in production, though there are some current upscale competitors like Armadillo and Happier Camper.
Any of them will be a good choice for your Odyssey. Consider adding a transmission cooler to reduce towing-related wear and tear. What year is your Odyssey?
Unless it's undergone a recent full renovation, there will certainly be issues with a 50 year old trailer. The biggest include rusted frames, worn out axles, and/or rotten floors. Broken or missing windows can also be troublesome, because many older windows are no longer being made. And of course, wiring needs updating, appliances don't work...
If you're wanting to avoid a project, consider a newer Scamp 13, something in the 5-15 year old range. Whatever the age, do a thorough pre-purchase inspection. Here's a tool you can download and print: Buyer's Checklist
Old 03-13-2023, 12:31 PM   #6
I don't have it yet.
Old 03-13-2023, 12:36 PM   #7
Jon in AZ - thank you for all of these suggestions, considerations and the checklist. Very helpful!
Old 03-18-2023, 10:46 AM   #8
Doug Payne's Avatar
Trailer: 1999 Bigfoot camper and 1986 UHaul trailer
The transmission in the Odyssey is a known weak spot. It doesn't do well in heat and pulling long grades. Personally, I wouldn't tow anything with it. You might want to add the largest transmission cooler that would fit. Manufacturers' towing ratings tend to be optimistic.
Doug Payne is offline   Reply With Quote
Old 03-18-2023, 11:04 AM   #9
Doug, I realized that at 221,000 miles now is not the time to start adding strain to the transmission. And being out West there are going to be long grades going out in any direction. Thanks for the reply.
Old 03-18-2023, 01:49 PM   #10
Doc.Kev's Avatar
We towed a Scamp 13’ with a 2007 Odyssey, took it to the 4 corners of America - Maine, Florida, California, Washington, over hill, over dale. The Honda worked great, 250,000 miles later it still runs. I did add a transmission cooler back in 2009. Used a WDH/anti sway, brakes, and exercised every caution. Good luck
Doc.Kev is offline   Reply With Quote
Old 03-18-2023, 03:27 PM   #11
Bill Robison's Avatar
Trailer: Eggcamper
Hi Lianee --
I have owned a 2007 EXL Honda Ody since new. I equipped it to tow our EggCamper (17') -- one of the most overlooked protections is a power steering cooler (I used a small trans cooler)... Also, I would recommend 'drain and add' fresh ATF often (30k miles) - do not use trans flushing... Best to you with enjoying your camper
'Do not go where the path may lead, go instead where there is no path and leave a trail.' - - Ralph W Emerson
Bill Robison is offline   Reply With Quote
Can I tow with Honda Odyssey Jerry W. Problem Solving | Owners Helping Owners 22 09-20-2013 08:37 PM
Do you tow with a Honda Odyssey? Frederick L. Simson Modifications, Alterations and Updates 33 11-14-2011 02:59 PM
SOLD - 2003 Casita Spirit Deluxe and 2005 Honda Odyssey Nancy Wright Classified Archives 10 03-15-2009 02:57 PM
99 Honda Odyssey as a tow vehicle? Cam A Problem Solving | Owners Helping Owners 6 03-01-2007 04:36 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
