Originally Posted by Linda Dumont
Lol! I will try and answer. The trillium is a 1977 4500. The furnace gas valve failed and when Chris pulled it out to see what was wrong, he discovered it had also burned through. So new furnace in order.
I'll try and post more pictures as I find them.
Linda, I suspect that your Trillium is in fact a 1978. The window in the door is the hint. Only in 1978 did the window open. Another indication would be the shape of your kitchen.
There are three variations of a 4500 kitchen. In the 1977 and earlier 4500s the kitchen was flat across the face. These used an RM211
fridge, like the 1300s.
In 1978 Trilliums the fridge jutted out. This allowed for a larger RM36 fridge, though the RM211 was still available. The two drawers on the left side of the kitchen lined up vertically.
In 1979 the converter, (120VAC to 12VDC) moved to the side of the kitchen. This required the drawers to be offset to make room for the converter. Also, the fridge changed to an RM360.
You can find pictures of these variations here:
https://www.fiberglassrv.com/forums/...ons-53368.html
Check your serial number against the list to confirm the year of your trailer. I started that list because I bought a Trillium that I knew was not the year that it was registered as.
BTW, Nice
paint job!
OK, now I see your additional pictures. You also have a 1978 style kitchen, with an RM36 fridge. The wall on the right-hand side of your kitchen implies that your Trillium is a front bathroom model.
I have a Couple of RM36 fridges, if you want to replace yours with the same model. My company allows me to ship from Calgary to various BC locations for free.
