Mike, Welcome to the site! We are a friendly and helpful lot. I am kind of a
Trillium geek. I will try to help as much as possible with your restoration project. Though I would ask for more interior pictures. The exterior pictures are good, but there is nothing of the front. Does it have a front
awning? Some pictures of the frame would also be appreciated.
There are six common issues with an old
Trillium:
- The
axle. They were designed to last 20 years. Eventually the rubber in the
axle eithe gets hard and provides no suspension, or it crumbles and the
axle sags:
https://www.fiberglassrv.com/forums/...ium-62389.html
https://www.fiberglassrv.com/forums/...les-77509.html
- The belly band. Yours is missing, but that may be best. I have done a couple of threads on deleting the belly band:
My First Belly Band Thread
My Second Belly Band Thread
- The door sags. Many threads on this subject:
https://www.fiberglassrv.com/forums/...air-47624.html
https://www.fiberglassrv.com/forums/...oor-70979.html
- The bolts holding the cab to the frame dissolve. There are six of them, two on the front and another two in each of the dinette seats. They need to be replaced.
https://www.fiberglassrv.com/forums/...ium-71429.html
https://www.fiberglassrv.com/forums/...day-69118.html
- The windows need to be resealed, and the wood frames on the inside are probably rotted in places. Lots of threads on this subject as well. One of them is mine:
My First Trillium window thread
https://www.fiberglassrv.com/forums/...all-87190.html
- The frame on early Trilliums needs to be reinforced where the frame comes out from under the front of the cab. There was a recall relating to this.
https://www.fiberglassrv.com/forums/...all-58535.html
https://www.fiberglassrv.com/forums/...air-87119.html
Some observations:
- Your serial number is 13-2201342, (take a look at the
serial number list)
- I assume that under the hubcaps that there are five bolts, not four.
- Your axle is riding low. A new one is probably in your future. I suggest one with
brakes.
- Your trailer has a
fridge, but no
furnace.
- That is the nicest spare tire holder I have ever seen.
- The gel coat on the roadside is worn through in places. Is that the result of sanding, or some other issue?
- As on all older Trilliums, you sink drains onto the ground. This should be changed to draining out a garden hose fitting, so it can be directed into an external grey water tank. Might plug up more that way though.
- A bolt lock on the inside of the door implies that the key no longer works. A new L-300 latch can be found. However, they are very expensive.
- There is a plastic cover for the screws around the windows. Available in a variety of colors.
- The
light by the door doesn't need a hole like that. I would close that up and buy the correct
light at an RV parts department.
- Princess Auto sells LED taillights that work and look OK.
