Welcome, Chi’s!
Start by reading the towing section of your owner’s manual. Depending on the year and model of your Wrangler, the tow rating could be as low as 2000#. That still gives you access to the smallest 13’ category of molded trailers, which comes in quite a few flavors.
Know that most of them are not really engineered for heavy duty off-road use. However they work well when taken on improved back roads and set up as a base camp for deeper exploration. A few people have renovated and strengthened an older unit with off-road use in mind.
One exception is the GoBE trailer. It’s small and basic, with a thicker shell than many and a robust frame and suspension designed for off-road use.
If you have a four-door Wrangler you have a few more choices up to around 16’.
Best wishes in your trailer search!
