Jeremy, I apologize if I am speaking, (typing?) out of turn, you didn't ask for my opinion, but I'm kind of a
Trillium fanatic.
Some comments on your pictures:
Picture 1:
The first thing I noticed was the date of manufacture sticker, just above the red sticker. I get excited by these. I started the
Serial Numbers on a Trillium thread because I purchased a
Trillium 1300 that I knew the date was wrong, but I could not find any way to figure out what year it was. That lead to discovering that some 1300’s had a sticker that included the serial number, and the date of manufacture. A Rosetta stone of sorts. Your trailer has one. If you are uncomfortable sharing your serial number, I totally understand. But if that is not a problem for you, I would love it if you posted a picture of the data sheet that is on the inside of your closet door, and a close-up of that sticker.
Also, I noticed a large number of screw holes below your front window. Weird. Do you know the story behind these?
Your front awning/rock guard looks to be in good shape. That is a real bonus. Many Trilliums have lost this. I suspect that they came off at highway speed when the latch opened. It is a good idea to confirm that it is secure before travel. It is nearly impossible to duplicate these today.
Picture 2:
Mud flaps! Very good! Your door seems to be hanging a bit low, and not quite straight. This is typical of Trilliums. The way the door is mounted is one of the flaws in the design. There are others, but more on that later. The metal ridge over your door could use some TLC. Some time with a pair of plyers and you can smooth that right out.
Picture 3:
The first hole that I noticed. What did the previous owner, (PO) do to this trailer? The rear bumper is also showing signs of impact.
Picture 4:
I like this. I am a fan of the
Trillium logo, and if a 1300 did not have a
fridge, then there was a road side logo. Trillium must have had two lower half molds, one with and one without the logo. Some seem to have had a
fridge added later, because you can still see the remnants of the chopped up logo. If you install a 12VDC compressor style fridge, then you don’t need to mutilate the logo. The fact that you have a
furnace is also very good. I love gravity furnaces. They are basically a fire in a box, simple and easy to fix. Since there is no fan, they use no electricity when operating. However these furnaces are no longer allowed in new construction. They lost their DOT / CSA approval as a result of high surface temperature. So high that they can ignite a fire if something flammable, (like a sleeping bag) is touching the front when they are running. You might want to keep that in mind.
Picture 5:
Problem. Both of the frame bolts in that picture have failed and are only being held in by rust. This is not uncommon, but you will want to replace all the bolts that hold the coach to the frame. In later years Trillium attached an angle iron tab to the frame and bolted through that instead of drilling hole in the square tube. This allowed them to use shorter bolts, and made the frame slightly stronger. You can change to this setup, but it would be best if the coach was off the frame, if you do. I’m guessing that the hole in the bottom of the coach is the drain for the water tank. Is your drinking water tank on that side?
Picture 6:
I see nothing of note, other than no
brakes.
Picture 7:
Furnace exhaust / air intake. The combustion air goes in the outside ring and the exhaust comes out the inside ring. The grill looks to be in OK condition, it only has one break. The fact that you only have a city water port and a water tank port, with no drain port, means that the sink is plumbed to a drain out the bottom of, what I call the pontoon, just in front of the wheel well.
Picture 8:
Big ouch! Did the PO have an explanation for the big hole? This can be fixed:
https://www.fiberglassrv.com/forums/...ass-52498.html
The frame reinforcement has been done strange. Why the perforated steel? Also, is that a from bolt totally missing the frame?
Picture 9:
More ouch. Given the damage, fixing this is probably best done with the frame off. I also see that what thought was a frame bolt is in fact a bent piece of ready rod.
Picture 10:
Early Trilliums had only one closet door. This makes the top space in the closet not very useful. In later years, Trillium put another compartment, with a door above the main compartment. You are missing a good deal of the T-molding. If you want to replace it, Paul Neumeister sells it:
https://fibreglass-rv.ca/catalog.html. It looks like your trailer spent some time wet as well. A new table top may be in order. The cushions have been recovered. And the curtains are newish.
Picture 11:
I am not seeing any
lights. Am I missing something?
Picture 12:
Lots of glue residue. I assume you are going to put down carpet, or flooring. That 120VAC outlet is not stock.
Picture 13:
The kitchen. Your
furnace is missing some of the front metal tabs. This may have been done intentionally to make it easier to
light. Later versions had an access hatch for
lighting and adjustment. This model required you to remove the whole front to
light it. However, I have a theory that people may have tried to adjust the air flow by bending the tabs and in short order, the tabs snapped off. The grill on this furnace is not the best design. However, the fire box makes more heat than later designs. It just has more surface area. If it doesn’t work, don’t worry, it can be fixed. There is enough room inside that it is not difficult to change the gas valve. In later models there was much less space inside. Beside the furnace is the ice box. Do plan to keep this? Simplicity is beautiful. Or are you going to put in a fridge?
Picture 14:
The ripples in your T-molding can be smoothed out by pulling it off, (it snaps back on) and boil it. I know how crazy this sounds, but the ripples are caused by repeated cycles of heating, which softens it up and causes it to expand thus ripple. Cooling causes it to harden in this condition. Heating the vinyl softens it up and if it is not installed, then it can harden up in a flat condition, smoothing it out. Then you can just snap it back on. The shower curtain rod holder is for a
fall restraint bar for the upper bunk. There should be another one on the opposite wall. Do you have the two piece bar, and spring?
Picture 15:
The beginning of belly band failure:
When I did a 1300 belly band:
https://www.fiberglassrv.com/forums/...ead-58763.html
When I did a 4500 belly band:
https://www.fiberglassrv.com/forums/...ead-59580.html
Picture 16:
An interesting perspective on the
axle. Also, I would mount your
propane fittings better.
