New with an old Bigfoot tandem 5th - Fiberglass RV
Old 05-17-2020, 02:52 PM   #1
Trailer: Bigfoot 5th wheel and Shadow Cruiser slide in.
Hi all from Ontario! We just purchased a 1988 Bigfoot Tandem 5'r. It has been well used and maintenance has been sketchy at best. Slept in it last night for first time. Went well lol.
Gonna be a project when I get my shop built then pull my boat tandem behind. Biggest part of it will be fixing delamination in the outside wall where the bathroom is. Has anyone pulled the bathroom out on one of these?? It will be beautiful when done...
Mike
Silverthorn is offline   Reply With Quote
Old 05-17-2020, 02:58 PM   #2
Steve Hammel's Avatar
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
Welcome, I've seen some of these polished up with the striping removed and/or modernized and they look terrific.
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT
Old 05-18-2020, 06:30 PM   #3
Tom Y's Avatar
Hi Mike, I did a extensive rebuild on a 86 model, best trailer I've ever owned. Have many miles on it and hope to get many more too. Ours came from Alberta, thru Victoria, then to Port Townsend Wa, where we lived at the time. Tows like a dream behind a half ton pickup.
I used epoxy for rebonding, probably the strongest, then I found a compatible with styrofoam spray glue that worked well also.
Heres a link to the rebuild files,
https://1drv.ms/f/s!Amaha7lilceMhhFS3M4pDuCT1N4v
Feel free to ask any questions during your rebuild and I'll try to answer, and enjoy your Bigfoot 5th wheel!
Tom Y
Tom Y is offline   Reply With Quote
Old 05-18-2020, 07:22 PM   #4
Nice work sir! Mine is definitely a project. Good thing retirement is not that far off lol. Did you have to fix the exterior wall behind the bathroom? Behind there and the fridge compartment is a tough on this one. Good thing I don't mind working on projects....
Old 05-18-2020, 09:21 PM   #5
Tom Y's Avatar
The exterior wall in the bathroom, behind the fiberglass bathroom shell was in good shape, I did cut in a small window in there, if needed you could do that to access that wall, also I removed the medicine cabinet to access the wall too. Under the sink and if needed if you pulled the hot water heater both those would offer some access to that wall.
I did do some rebonding of the exterior wall behind the heater and fridge, emptied that area then rebuilt the wall.
In inaccessible areas that have dis-bonded try to inject epoxy between the layers using a large syringe with thin wall flexible tubing attached from any accessble edges, or if necessary inject the disbonded area by drilling a small hole thru the interior paneling, inject with epoxy, plug the hole and clamp or block the area flat till the epoxy cures.
Btw, the fiberglass bathroom pan was not bonded to that exterior wall from the factory, so it is normal for it to have some flex, behind the pan is the same construction as the other walls in the camper, exterior wall glued to the foam core and wood paneling glued to the core on the inside.
That's where the dis-bonding can occour.
bigfoot
1987 bigfoot 5th wheel tandem trailer $12,500 stude Referrals: Molded Fiberglass Trailers 0 06-27-2018 01:32 PM
SK | =sold 1987 Bigfoot TF20 Tandem Axle 5th Wheel (20 ft.) $8600 Brenda Novakovski Classified Archives 4 05-10-2013 12:23 PM
20' 5th Wheel tandem axle fiberglass trailer blaine gilruth Classified Archives 4 09-25-2010 07:26 AM
1985 "20 ft Bigfoot tandem axel" 19ft 5'er? $6200 Robin G Referrals: Molded Fiberglass Trailers 0 02-14-2010 11:09 AM
1986 Bigfoot 5th Wheel - eBay - Tandem Axle pete luchka Classified Archives 3 09-06-2009 12:16 PM
