Power inverter - Fiberglass RV
RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-19-2020, 05:39 AM   #1
Trailer: 1974 Boler
Smile Power inverter
Hi. My name is Velma.
I own a 74 Boler. Can someone please help me, I want to set up I'm guessing a power inverter so I can run my 12volt appliances.
I have no fuse box, just a plug that hooks up at a campsite. I want to install a roof vent with fan, and definitely need more lights.
Any help would be much appreciated.
Thank you in advance.
Velma is offline   Reply With Quote
Old 08-19-2020, 06:51 AM   #2
AC0GV's Avatar
Wisconsin
12 VDC
A converter will run the 12 VDC items and charge the battery from the 120 VAC campground hookup. Most have both the converter and a battery but a converter or other 12 volt power supply alone will work if you are plugged into electric. My sisters Scamp had nothing but a battery charger to run things.
Old 08-19-2020, 09:29 AM   #3
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Velma, an inverter converts 12vdc from a battery into 120vac. As stated, the converter changes 120vac to 12vdc, which all the things you mention need. If you do not have experience with electricity, please find someone who does to help you.
Old 08-19-2020, 10:04 AM   #4
Trailer: 1974 Boler
Thank you. I will definitely find someone to help.
Old 08-20-2020, 04:30 AM   #5
Doug Arthurs's Avatar
Is that Ontario Canada? We are in London if you are near by I may be able to help you.
Doug Arthurs is offline   Reply With Quote
Old 08-20-2020, 06:55 AM   #6
Trailer: 1974 Boler
Hi Doug. I live in Mississauga, thank you for the offer. I really appreciate it.
Power Inverter - a Question Mac B Problem Solving | Owners Helping Owners 7 11-13-2009 02:46 AM
Vector® 750 - watt Portable Power Inverter Kevin K Classified Archives 0 04-25-2008 10:55 AM
Wiring Inverter, Converter, and Power Transfer Relays. GeorgeR Modifications, Alterations and Updates 3 01-31-2008 11:50 AM
Power Inverter for Charging Laptop in the car? V'sGlassSleeper General Chat 24 09-03-2007 10:28 AM
Generator vs Power Inverter Bob H Electrical | Charging, Systems, Solar and Generators 15 09-05-2006 10:32 AM
