Refrigerator troubles - Fiberglass RV
Old 03-09-2020, 10:35 AM   #1
Have a 2014 scamp plugged trailer in last night getting ready for a three day trip. Today refrigerator isnít cold? Worked fine on elec or gas last month, help please?
Lockmasterjoe is offline   Reply With Quote
Old 03-09-2020, 12:15 PM   #2
Check the simple things first. Make sure fridge plug is still in, circuit breakers are all on, and a GFI between the house and trailer may have tripped.
Old 03-09-2020, 12:20 PM   #3
if on gas when you light it you should feel heat on your chimney where the gas is lit! I have never ran mime on el. but you should feel heat somewhere outside on your fridge.
are you sure you have gas in your tank?
bob
Old 03-10-2020, 04:41 AM   #4
Trailer: 1979 Boler 1300 / 1991 Casita Freedom Deluxe
Maine
On our trip cross country last summer, our fridge wasn't cooling well at all when we got to the Grand Canyon and I first tried to blow from bottom up the chimney and quite a bit of soot came out and fridge worked a bit better. The next day I removed the top grill and found that there was actually a cleaning rod down in the chimney that I had never used. I pulled this rod up and down several times and it screws its way along the wall of the chimney and clears the soot.
Fridge worked the remaining 2 months of the trip with no problems on Gas.
Old 03-10-2020, 08:27 AM   #5
where is this rod
is this rod at the very top of your chimney? I need to check this!
thanks
bob
Old 03-10-2020, 01:42 PM   #6
Raz
Raz's Avatar
Vermont
If you are referring to part number 102 in the diagram, thats the baffle. I believe its purpose is to slow the rising heat. I clean it when I clean the chimney. Click image for larger version
Old 03-10-2020, 04:32 PM   #7
Maine
Raz, my "T" handle was gone and that thin wire was just hooked over the top edge of chimney.
Great Diagram.
refrigerator
help!! toilet troubles... kelley m Plumbing | Systems and Fixtures 5 06-20-2013 06:40 AM
greece financial troubles john warren Jokes, Stories & Tall Tales 1 07-13-2012 04:11 PM
Troubles running off battery alone. byAndrewDavis Problem Solving | Owners Helping Owners 14 04-01-2011 09:08 AM
boler 7 pin connector troubles al gilliland Problem Solving | Owners Helping Owners 6 04-24-2007 01:02 PM
Money troubles? Legacy Posts Jokes, Stories & Tall Tales 0 06-20-2003 12:07 PM
