With molded
fiberglass you’re likely looking at a minimum budget of $12-15K for a unit with a bathroom that’s not a huge project. That’s the bad news. Good news is prices seem to be stabilizing and softening. It will take some patient searching.
Besides the appliances, consider the chassis and floor. Rusted frames and rotted floors make for big projects. Many people don’t realize all vintage and many newer
fiberglass trailers use wood as structural support in the floor. In some it’s exposed; in others it’s encased in
fiberglass. Any can become rotten given enough time and neglect. Inspect underneath and inside every cabinet and bench looking, poking, and smelling for signs of water damage.
There is a helpful buyer’s inspection checklist in the Document Center (in the “More” tab). Download, print, and take it with you when you check out a potential purchase. Best to take a second set of eyes not emotionally invested in the purchase, even better if they have some RV experience. If that isn’t possible, you can post photos and ask questions in real time here.
With a limited budget, be prepared to kiss a few frogs before you find a “prince.”
A 16’er will stretch the capabilities of your vehicle. I’ve read a number of reports from folks towing 16’ers with the 2.0EB
Escape, and the consensus seems to be “barely adequate, slow on hills.” Scamps tend to run a bit lighter than Casitas, and keeping it simple and basic helps. You can find 13’ers with bathrooms, but storage may be a problem.
Nothing
light enough for your vehicle is going to be suitable for winter weather, so all this assumes you can follow the seasons with your work.
