First thing I'd check would be to pop the hood on your truck and check your battery's POS (+) terminal for an extra black wire, (not the heavy wire,) and within a few inches of where it attaches to the
battery there is usually an in-line fuse holder. Check the fuse, as it may be blown. If you have a self-resetting circuit breaker instead of an in-line fuse, it may be shot and needs to be replaced. Anyway, if you don't have any power on the downstream side of the black wire that feeds the 7-Pin Bargman trailer connector, that would be the first pace to start looking. If you have power near the
battery, but not reading power inside the 7-Pin connector on the back of the truck, then your problem is in the wire between the two points, which needs to be checked for damage or being disconnected.
